Author Topic: HELLOOOO diesel PEOPLE! and etc...  (Read 22198 times)
Reply #60June 05, 2011, 02:31:54 pm
Digital K
  • 58
Re: HELLOOOO diesel PEOPLE! and etc...
« Reply #60 on: June 05, 2011, 02:31:54 pm »
IF I ever need a pump rebuild I'd do it through Giles no question.  What you get back from him is a whole lot more than a resealed pump with the governor tweaked!  Jezzie got a new (!) pump just before I bought her so I doubt I'll be doing anything in that department for a long time.
Typical pump reseal is about $400 or so if you have a Bosch shop do it, and you get your same old worn out parts back.  $1k with Giles gets you fresh internals plus a pump with:
- Boost enrichment tuned for your engine (you tell him what you are running, IC, etc, he will set up the LDA with the proper spring, etc)
- Dynamic timing re-curved (lots more advance - stock advance curve injects fuel way too late at high RPM)
- Pump is balanced so all 4 cylinders get exactly the same metering
- Governor actually PROPERLY tuned for high RPM rather than just some shims jammed in there
- Upgraded cam plate on the 1.6 engines
- Tuning assistance by Giles :)
It's a lot of coin, but it's certainly worth it.
I would feel much better about it if I saw before and after dyno numbers....
found out the car is quite a bit faster than a mini cooper S yesterday :)
on the timing cover note, I did inquire at the dealer awhile back to get a non broken one. they seem to be NLA? If I found one Id probably find a way to get it on, but im not going to NOT drive my truck in the meantime.
Reply #61June 05, 2011, 07:25:40 pm
« Reply #61 on: June 05, 2011, 07:25:40 pm »
tyler did a before and after dyno on his na mk2 i believe.  i think he gained like 20 hp and atleast 10hp through out the power band
Reply #62June 05, 2011, 07:26:47 pm
« Reply #62 on: June 05, 2011, 07:26:47 pm »
91 Golf NA. Stock run plus a stock+Giles pump run
Reply #63June 05, 2011, 10:13:45 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #63 on: June 05, 2011, 10:13:45 pm »
See, Kris? It really is worth it ;)
Reply #64June 06, 2011, 09:51:49 am
« Reply #64 on: June 06, 2011, 09:51:49 am »
the difference was the fuel pump.. thats it..
Reply #65June 06, 2011, 09:10:59 pm
Digital K
  • 58
« Reply #65 on: June 06, 2011, 09:10:59 pm »
1000 bucks for 10-20hp? eek. I dunno about that....
Reply #66June 07, 2011, 05:06:09 am
« Reply #66 on: June 07, 2011, 05:06:09 am »
That is on an N/A...There is probably nothing else to get you 20 hp on an N/A. If you wanted to mod more after that then it would yeild even more.
AND the N/A pump is not 1000.00 it is more like 650 IIRC. My TD pump was 900.--
Reply #67June 07, 2011, 05:33:00 am
punkvideo81
  • 168
« Reply #67 on: June 07, 2011, 05:33:00 am »
Someone really needs to do a full write up on just what's possible with a 1.6td or 1.9 aaz with some good mods + Giles pump. Once my project's done I'll try to document it all.
'81 Caddy 1.6 TD
Reply #68June 18, 2011, 06:47:34 pm
dl_sledding
  • 48
« Reply #68 on: June 18, 2011, 06:47:34 pm »
Over on the Vortex, I once asked what the 1.6 was capable of (http://forums.vwvortex.com/showthread.php?4993878-1.6-TD-max-power)...  This was one of the answers I got:
Giles pump, as well as lots of other goodies, were involved...
Reply #69June 18, 2011, 08:46:41 pm
trav1856
  • 230
« Reply #69 on: June 18, 2011, 08:46:41 pm »
$700-750 at last quote from Giles. He's on the list, he may chime in.
1981 Rabbit Diesel
1981 Cabriolet
Reply #70June 19, 2011, 12:10:50 pm
fdnyguy
  • 499
« Reply #70 on: June 19, 2011, 12:10:50 pm »
Not a fan of low riding cars, but those 2 are beautiful.
Is the truck for sale???? Swore I saw it on the Samba or something....
Say safe, stay well. Jimmy.
Never forget what a "Religion of Peace" did on 9/11/01.
2015 Passat TDi. 27k
1998 Jetta 1.9TTDi 228k .
2002 F250 7.3 TD   63,000 miles. Sold.
1980 Mack CF Fire Engine. Working on it.
2007 Dodge MegaCab 5.9 Cummins. Nice, but plagued with issues
