Author Topic: Bad spark plug wire???  (Read 6778 times)
Reply #15March 07, 2011, 09:39:07 am
maxfax
  • 2126
Re: Bad spark plug wire???
« Reply #15 on: March 07, 2011, 09:39:07 am »
I must have some crap luck..   All the electrical issues I see on here, I've never had any of them in any of my VW's.. I've had all the typical water leaks and so on too..   I've run into pump solenoid problems on other's cars, but it was usually much more drastic bucking...  I had to debate for a long time if it was indeed a miss, or rough rod/bad tires..
I put a new ignition switch on and ran a new wire this morn..  I'll find out how it does I guess..
Reply #16March 09, 2011, 07:05:08 pm
maxfax
  • 2126
« Reply #16 on: March 09, 2011, 07:05:08 pm »
HA! HA!  Success!!  2 days and not a stutter..  Time to remove the oil from the expansion tank again..  ::)
Reply #17March 11, 2011, 05:04:29 am
macka
  • 957
« Reply #17 on: March 11, 2011, 05:04:29 am »
you crack junky  8)
Quote from: Vincent Walden
Reply #18March 11, 2011, 08:50:19 am
maxfax
  • 2126
« Reply #18 on: March 11, 2011, 08:50:19 am »
you crack junky  8)
I'm all about the crack man......   :P
Reply #19March 11, 2011, 10:21:54 am
« Reply #19 on: March 11, 2011, 10:21:54 am »
your engine did not overdose from it tho..
mine did..
ive been clean of crack for a few years now..
wonder if im ever gonna relapse? im running an 11mm block again, lol.
Reply #20March 11, 2011, 11:05:36 am
maxfax
  • 2126
« Reply #20 on: March 11, 2011, 11:05:36 am »
Well, it did overdose, took a ride to the ER then rehab... It was in recovery for a while, but I think it's in the process of a relapse..
Glutton for punishment??  I've finally used up the last of my 11mm block stash..  Still have a few heads though....
Reply #21March 12, 2011, 10:18:47 am
« Reply #21 on: March 12, 2011, 10:18:47 am »
friggen 84 rabbit i have came with a CS engine in it.. so not much i could do about it.
i only have one 12mm engine, its a real TD, and it needs a rebuild..
