Author Topic: Oil in Coolant  (Read 8912 times)
Reply #15February 20, 2011, 03:43:41 pm
maxfax
  • 2126
Re: Oil in Coolant
« Reply #15 on: February 20, 2011, 03:43:41 pm »
From what I understand is ALL the diesel engines were made and assembled in Germany but shipped to where ever the car was built....  My guess is that there were some left over 11mm engines floating around that got used on '82 models.. TO be honest, I've never found a 12mm '82 model in this neck of the woods..
Reply #16February 21, 2011, 08:26:54 am
Re: Oil in Coolant
« Reply #16 on: February 21, 2011, 08:26:54 am »
i dont find 12mm cars over here till 83/4 cars..
everything else has 11mm engines. and they are the correct numbers matching engine too.
Reply #17February 21, 2011, 11:10:24 am
jaysen71581
  • 211
    Hagerstown, MD
Re: Oil in Coolant
« Reply #17 on: February 21, 2011, 11:10:24 am »
Just make sure there are no cracks in the motor either, look at where the head bolts to the motor on the passenger side of the motor, found that out the hard way ...
Reply #18February 23, 2011, 07:40:20 am
rdezsofi
  • 19
Re: Oil in Coolant
« Reply #18 on: February 23, 2011, 07:40:20 am »
.....uh.....not exactly. I'm working on a 1.6 that has 'Germany' stamped on the outside. I know for a fact the motor has never been opened. However, on one of the main bearing caps, it clearly says 'Mexico.' I think it's likely the blocks were cast in germany and sent to Mexico or wherever for the final work.
Reply #19February 23, 2011, 09:21:49 am
Quantum TD
  • 1195
Re: Oil in Coolant
« Reply #19 on: February 23, 2011, 09:21:49 am »
That, and nearly all of the 11mm 1.6 Blocks I've seen here in the USA were cast in Brazil: and they're junk castings aside from (or in conjunction with) the fact that the bolt holes crack. The bores wear out faster than similar-mileage German castings.
Reply #20February 23, 2011, 12:06:08 pm
maxfax
  • 2126
Re: Oil in Coolant
« Reply #20 on: February 23, 2011, 12:06:08 pm »
Correction
From what I understand is ALL the diesel engines were made and assembled  made/assembled in Germany
But indeed not everything was cast in Germany.. And I should also add AFAIK it was just the earlier (mostly 11mm) engines..
 I've had about 50/50 Brazilian cast / German cast blocks..  Oddly enough I have one of the Brazilian blocks with no cracks in the deck around the bolt holes, the crack was in the bore..  :-\
« Last Edit: February 23, 2011, 03:50:20 pm by maxfax »
Reply #21March 06, 2011, 11:26:18 am
trav1856
  • 230
Re: Oil in Coolant
« Reply #21 on: March 06, 2011, 11:26:18 am »
Drained the oil today. There's no coolant in the oil, so I suspect it's either headgasket leakage, or it's leaking up a bolt and into the coolant. (then again, maybe the previous owner was an idiot and bought into the "oh just add a quart of oil into the coolant" school of thought)
So the next step will be to drain my coolant and just keep an eye on it for oil.
1981 Rabbit Diesel
1981 Cabriolet
Reply #22March 06, 2011, 11:38:09 am
Re: Oil in Coolant
« Reply #22 on: March 06, 2011, 11:38:09 am »
Oil pressure = 80+ psi
Coolant pressure = 15 psi
So, you'll almost always find oil in the coolant with a oil-to-coolant passage headgasket breach,  but rarely the other 'way round... 80 psi > 15 psi.   :)
