Author Topic: grrrrr, wont start!  (Read 7383 times)
Reply #15February 16, 2011, 06:23:16 pm
truckinwagen
  • 1895
Re: grrrrr, wont start!
« Reply #15 on: February 16, 2011, 06:23:16 pm »
well, the pump I got is a square facet pump, but not a crap one.
gonna go slap it in right now...
-Owen
83 Opel Kadett Diesel
Reply #16February 16, 2011, 07:12:03 pm
maxfax
  • 2126
« Reply #16 on: February 16, 2011, 07:12:03 pm »
YEah, when you said what the list price was I figured it wasn't crap.  The one's I'm referring to list for what you paid for yours..    Good luck!!!
Reply #17February 16, 2011, 08:09:41 pm
truckinwagen
  • 1895
« Reply #17 on: February 16, 2011, 08:09:41 pm »
Turns out my starter is grap.
It is cutting out and retracting the gear about once a second, and then starts right back up again.
Grinding the ring gear and turning the motor over to slow to start.
And its brand new!
Gonna go see if there is a starter local that will fit (like one from an iron duke)
Reply #18February 16, 2011, 10:33:02 pm
truckinwagen
  • 1895
« Reply #18 on: February 16, 2011, 10:33:02 pm »
well, I took a look at some starters(pictures of them at least) and it looks like either a starter from a early S10 gas or diesel will work.
I will confirm that one of them will work tomorrow, I will head over to the parts store with my starter and a pair of calipers to make sure they fit the same.
the gas starter is a direct drive, built for a 1.9L gas motor, and as such would not be ideal(and would probably die prematurely)
the diesel starter is a gear reduction unit that would be better if it fits, but is much more expensive($130 vs $30)
both are cheaper than one for my car(which might be bad again anyway) and are here in town
-Owen
Reply #19February 17, 2011, 07:51:07 am
« Reply #19 on: February 17, 2011, 07:51:07 am »
can you get an a/c delco starter? or are you stuck with chinese junk?
Reply #20February 17, 2011, 05:54:52 pm
macka
  • 957
« Reply #20 on: February 17, 2011, 05:54:52 pm »
IIRC you can scoop a starter from a 3.8 lumina minivan and swap the guts over. Pretty much a Bosch inside
Quote from: Vincent Walden
Reply #21February 17, 2011, 07:29:37 pm
truckinwagen
  • 1895
« Reply #21 on: February 17, 2011, 07:29:37 pm »
well, got the starter rebuilt by a local shop today.
$189, but it was same day service.
turns out the starter is a hitachi.
gonna install it later and see if that fixes it.
-Owen
Reply #22February 17, 2011, 07:31:43 pm
maxfax
  • 2126
« Reply #22 on: February 17, 2011, 07:31:43 pm »
Chances are good they used no China junk parts too...
Interesting..  I would have bet extra body organs it was a Nippendenso...
Reply #23February 17, 2011, 09:44:06 pm
truckinwagen
  • 1895
« Reply #23 on: February 17, 2011, 09:44:06 pm »
well, got it started, the new starter did the trick.
spins much faster, but is still chewing on the ring gear...
gonna pull the starter this weekend at my buddies shop and see if the ring gear is too chewed up, or if it is the new starter being stupid.
also gonna install the cat filter and finish the lift pump install.
-Owen
Reply #24February 17, 2011, 10:32:43 pm
maxfax
  • 2126
« Reply #24 on: February 17, 2011, 10:32:43 pm »
Hopefully it's nothing more than maybe needing to dress the teeth on the ring gear..  Had that happen on my 6.5 Chevy.. Got lucky that a little tedious work with a file took care of what a crappy China starter did...
