Author Topic: wheels, corrado 4x100 brakes (11"?)  (Read 4378 times)
February 03, 2011, 02:31:58 pm
erice1984
  • 263
« on: February 03, 2011, 02:31:58 pm »
I have some 91 corrado 4 bolt brake setup that the previous owner put on my rabbit.  I was wondering if its possible to squeeze 14" wheels over the setup.  I know corrado's came with 15" and the smallest diameter VW ran on them was 15".
Reason for asking is because I want narrower rims/tires for the winter, and its hard to find 15x5, easier to find 14x5.
1980 Rabbit 1.9TD
Reply #1February 03, 2011, 10:26:56 pm
GEE-BEE
  • 1604
Re: wheels, corrado 4x100 brakes (11"?)
« Reply #1 on: February 03, 2011, 10:26:56 pm »
No
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2February 17, 2011, 09:02:22 pm
AudiVWguy
« Reply #2 on: February 17, 2011, 09:02:22 pm »
GEE-BEE is right. When I put on my summer tires (15's) I take off my 10.1's and put on the 11" rotors. Stopping power is better and it looks cool seeing that much rotor lurking in there. 8)
Cheers,
-JB
Reply #3February 17, 2011, 09:05:41 pm
erice1984
  • 263
« Reply #3 on: February 17, 2011, 09:05:41 pm »
nice.  I was looking into downsizing the rotors.  I have PLENTY of braking with 11" rotors.  So the 10" rotors from a scirocco will fit?  Do I use the same calipers as with the G60?  or how does that work?
1980 Rabbit 1.9TD
Reply #4February 18, 2011, 09:29:17 am
GEE-BEE
  • 1604
« Reply #4 on: February 18, 2011, 09:29:17 am »
G60 fit
G60 brakes are very cheap ( rotor's)
adapters for the MK1 from [email protected], he also makes the ebrake cables for the caddy's
I did all new s/s hardlines and G60 brakes
22 mm master with MKII pedal swap , MKII brake switch
16V prop valves ( scirocco )
Stops like my Porsche
Giles Pump OHC
MK1 JETTA DASH
Reply #5February 18, 2011, 09:32:00 am
erice1984
  • 263
« Reply #5 on: February 18, 2011, 09:32:00 am »
That's about what I have in my rabbit right now.
I was wondering what parts I would need to change to get the scirocco 10" brakes on the car.  I think the calipers are different from the G60 and rocco, and of course brake pads and rotors are different.
So I just want to know if G60 calipers and rocco calipers are the same, and probably not.
1980 Rabbit 1.9TD
Reply #6February 18, 2011, 10:09:17 am
GEE-BEE
  • 1604
« Reply #6 on: February 18, 2011, 10:09:17 am »
Different
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #7February 18, 2011, 11:14:45 pm
mystery3
  • 774
« Reply #7 on: February 18, 2011, 11:14:45 pm »
Can you get good winter tires in appropriate sizes for a 15x5 wheel? If so you could get some diamond racing wheels, reasonable price, whatever offset.
Reply #8February 19, 2011, 06:49:26 am
erice1984
  • 263
« Reply #8 on: February 19, 2011, 06:49:26 am »
nice, thanks mystery.  Blizzaks WS60 are made 175/55/15
1980 Rabbit 1.9TD
