Author Topic: hybrid isuzu/cummins pump finished!  (Read 8903 times)
Reply #30February 03, 2011, 03:01:35 pm
truckinwagen
  • 1895
Re: hybrid isuzu/cummins pump finished!
« Reply #30 on: February 03, 2011, 03:01:35 pm »
well, I retarded the timing to where the clatter at idle was almost eliminated, and now it hits the stumble and looses power at 3000RPM
gonna time it in the middle for now, so it is more drivable(with a 3-speed I need to rev past 3K alot) and then get the softer spring for the advance to fix the problem outright.
-Owen
83 Opel Kadett Diesel
Reply #31February 03, 2011, 06:20:02 pm
truckinwagen
  • 1895
« Reply #31 on: February 03, 2011, 06:20:02 pm »
that I did not swap over, and it is easy to do(not hidden by the intake manifold)
I'll try that.
I did clearance my spare timing spring cover(to allow more total timing advance) to go with the softer spring, if it comes to that.
but to get to the timing advance cover I have to pull the pump, so I will wait until I get the green spring before I do that.
-Owen
Reply #32February 03, 2011, 08:48:10 pm
truckinwagen
  • 1895
« Reply #32 on: February 03, 2011, 08:48:10 pm »
cool, thanks!
Reply #33February 04, 2011, 12:21:59 am
« Reply #33 on: February 04, 2011, 12:21:59 am »
Which pressure regulator did you use?  They are specific to the plunger size so you'd need to use the cummins one.
My gut feeling says that'll fix it ;D
Reply #34February 04, 2011, 04:39:55 pm
truckinwagen
  • 1895
« Reply #34 on: February 04, 2011, 04:39:55 pm »
well, changed the regulator.
it helped, but not much, moved the stumble from 3000 to 3250RPM
gonna go forward with the softer advance spring.
-Owen
