Author Topic: WTB: 1Z Alternator Bracket and 120A Alternator  (Read 3791 times)
January 11, 2011, 02:06:08 pm
redlock
  • 2
« on: January 11, 2011, 02:06:08 pm »
I need an alternator bracket from a '97 Passat 1z engine and the matching alternator. I'm doing a vanagon tdi conversion and the donor was in a front-end wreck. The alternator tabs and the bracket are broken so need both. The bracket has part number 028903143AB stamped on it, but I believe the vw part number is 028903139T. Will also consider a 90A alternator if you've also got the matching bracket that fits this motor.
Thanks,
Bill Knight
Raleigh NC
Reply #1January 11, 2011, 04:44:07 pm
GEE-BEE
  • 1604
Re: WTB: 1Z Alternator Bracket and 120A Alternator
« Reply #1 on: January 11, 2011, 04:44:07 pm »
Try ebay for the alt
I picked up a ohc Bosch 90 amp for 85.00
I know the partsplaceinc has new 1.9 aaz alt brackets with roller and arm for 189.00
Next will be a clutch pulley
try this one, the have the complete setup:
http://foreignautosupply.com/Tiico_Owners_Page.html
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2January 11, 2011, 04:55:49 pm
redlock
  • 2
« Reply #2 on: January 11, 2011, 04:55:49 pm »
Thanks for the tip about partsplace, they might have a bracket. Yes, I can probably get the alternator somewhere like ebay, but the problem I'm having is with the bracket, it is a diesel specific bracket that needs to align with the IP bracket. The TIICO bracket is for the gas motor. Thanks for the help!
