Author Topic: Possible Scirocco for TD project?  (Read 42059 times)
Reply #120June 19, 2011, 08:33:59 pm
Powered by Spearco
  • 1203
Re: Possible Scirocco for TD project?
« Reply #120 on: June 19, 2011, 08:33:59 pm »
Boy, it seems like this steering issue will never end. So the rack fits great and so does the steering shaft to the colum, but the lower colum bearing was destroyed due to age and IIRC they are NLA, also the steering colum shaft is an early version which means that the bearing that fits the later versions of colums are different. So I had to change the colum shaft to the newer style and lower bearing, which I had. BUT...the quick release steering wheel adapter was welded on by the PO. So I cut it off and then noticed that it was never intended to fit a VW steering shaft. I'm going to nix that whole setup and get an NRG brand quick release system with adapter hub. Heres a link...
http://www.getnrg.com/products/quick-release-kits/short-hub/feed.
http://www.getnrg.com/products/quick-release.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #121June 20, 2011, 02:11:55 pm
« Reply #121 on: June 20, 2011, 02:11:55 pm »
those lower bearings are a real pita, nice to see this coming along, will be great to see it running and driving
Reply #122June 23, 2011, 09:41:52 pm
Powered by Spearco
  • 1203
« Reply #122 on: June 23, 2011, 09:41:52 pm »
Did you know that sanding round things sucks  :-\. It takes forever  ;D.
I got a chance to start sanding the frame tubing and firewall. Most of the paint on the tubing was so beat up from rock chips and road debris, just throwing on some paint, it would look like poop. So I'm using 80 grit emery cloth to cut through the chips to metal. I've got some metal etch primer that I'll paint it with first before the flat black paint goes on.
New Hoosier tires are ordered up and should be here by Wed. next week. Uber sticky autocross tires, heat cycled and ready to go for any road race or hill climb event. Still waiting for the other Circle wheel to be built and sent, maybe next week as well. Still need drag slicks too.
'13 Golf R:. Tuned
'98 Puch G320
Reply #123June 23, 2011, 10:23:25 pm
81 vw pu
« Reply #123 on: June 23, 2011, 10:23:25 pm »
I here ya on sanding the tubing, helped my brother-in-law do 2 sand rails last summer. Took a lot more paint than we expected as well.
I think we got more paint on the shop floor than on the tubing. Also found 2 places we forgot to weld up while we were painting.
I think next time its gonna be paint stripper and a pressure washer.
Reply #124June 23, 2011, 10:34:57 pm
Powered by Spearco
  • 1203
« Reply #124 on: June 23, 2011, 10:34:57 pm »
Thats what I was thinking, aircraft striper and pwr washer. Oh well, next time  ;D. Thanks for the heads up on getting paint on the floor. I think I'll setup some plastic on the floor before.
'13 Golf R:. Tuned
'98 Puch G320
Reply #125June 23, 2011, 10:59:24 pm
81 vw pu
« Reply #125 on: June 23, 2011, 10:59:24 pm »
That aircraft stripper is wicked stuff. I helped a ag pilot I used to work for strip an old bell 47 helicopter with it.
Worked great till we got down to the original military OD green. Had to sand the green off. Only bad thing about
stripper was any cracks/pinholes or rivets makes it hard to get the stripper out of and leached back out when we painted.
Reply #126June 24, 2011, 04:54:41 pm
RadoTD
  • 513
    Stage WTF
« Reply #126 on: June 24, 2011, 04:54:41 pm »
You just need a Fein Pipe Sander! For a mere price of $2000 haha
http://v1.fein.de/corp/us/en/fein/products/stainless/rs.htm
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #127June 24, 2011, 05:28:13 pm
« Reply #127 on: June 24, 2011, 05:28:13 pm »
I could get you a 3M file belt sander for under 400.00 :D
Reply #128June 24, 2011, 05:55:01 pm
81 vw pu
« Reply #128 on: June 24, 2011, 05:55:01 pm »
I know a meth addict that will do it for $40, you gotta tell him when he's finished though!!! ;D
Reply #129June 24, 2011, 06:03:46 pm
« Reply #129 on: June 24, 2011, 06:03:46 pm »
LMFAO!!!  ;D
that was a good one!
Reply #130June 26, 2011, 07:20:00 pm
Powered by Spearco
  • 1203
« Reply #130 on: June 26, 2011, 07:20:00 pm »
Its been painted and also made a new upper strut tower brace thats removable. I want to give a shout out to my buddy Travis for building the brace. Thanks dude.
Looks like the colors will contrast great.
'13 Golf R:. Tuned
'98 Puch G320
Reply #131June 26, 2011, 10:55:07 pm
RadoTD
  • 513
    Stage WTF
« Reply #131 on: June 26, 2011, 10:55:07 pm »
Oh dang that's sexy! This is going to be awesome all bolted up! I might have to make a road trip down to Oregon once it's running :P
Reply #132June 27, 2011, 03:19:05 pm
« Reply #132 on: June 27, 2011, 03:19:05 pm »
yeah looks like you made room for compound turbos  ;D
Reply #133June 27, 2011, 08:02:00 pm
Powered by Spearco
  • 1203
« Reply #133 on: June 27, 2011, 08:02:00 pm »
Ha ha. Compounds are next time around. I'm really in a rush to finnish this up for any time behind the wheel, but there is still a bit to do. Plus I might be running out of the shop space to work in.
Yeah, come on up for the NW Diesel Nationals this August.
'13 Golf R:. Tuned
'98 Puch G320
Reply #134June 29, 2011, 08:27:57 pm
Powered by Spearco
  • 1203
« Reply #134 on: June 29, 2011, 08:27:57 pm »
Spent some time building the fuel cell bracket/mount. Needs finnal welding to chassis.
Tires are getting mounted and will be deliverd tomorrow  :D.
Ordered up a Dyno tune nitrous progressive controller along with a NRG steering wheel hub adapter and quick release steering wheel adapter hub. Those should be here by the end of the week.
'13 Golf R:. Tuned
'98 Puch G320
