Author Topic: Valve cover beather hose  (Read 9983 times)
Reply #15December 10, 2010, 12:32:51 pm
jseeley
  • 106
Re: Valve cover beather hose
« Reply #15 on: December 10, 2010, 12:32:51 pm »
my 84 rabbit is equipped with a CS engine.. should have had a CR from the factory. and im the SECOND registered owner of the rabbit. but i know for a fact that it did get an engine swap.
and most MK2 cars had the same style of intake manifold as you tho. it wasnt CS only, most likely just a particular hose..
as for making it loud, just turbo it. best muffler ever!
if your keeping it n/a, then dont put glass packs on it.. use real resonators. glass packs are SUPER RAPPY on diesels.. my rabbit would start rapping at about 1500 rpms. but that was with tiny stock tail pipe still.. the bigger the pipe you run, the less loud it is, but the more chances for "diesel drone"..
you got the right manifold and downpipe for your chassis right? idk how many times ive seen people try and use mk2 manifolds and downpipes on mk1s, or the other way around..
Mines a mk2, so if most of them had that intake setup, then it makes sense. It will be staying NA (I'll do turbo with a 1.9 m-tdi someday...) I HOPE it's the right manifold and downpipe. It's from an 8V GTI mk2. I also have a 2.25" resonator from a VR6 Corrado, as for the muffler and the 2nd resonator... Not sure yet. I dunno too many people experimenting with resonators and exhaust setups for 1.6 NA's... at least locally were I could hear the differences. I have herd a "turbo" muffler is good as it adds no back pressure.
« Last Edit: December 10, 2010, 12:35:16 pm by jseeley »
85 Golf Diesel 1.6 NA 240K miles? (odometer broken)
87 Cabriolet 1.8 Gasser 104K miles
05 Golf 2.0 Gasser 66k miles
03 Jetta Wagon TDI 112k Miles
Reply #16December 10, 2010, 01:15:43 pm
« Reply #16 on: December 10, 2010, 01:15:43 pm »
turbo mufflers DEFINITELY add back pressure..
anything you cant see through, pretty much for sure adds back pressure..
its not going to be too terrible loud since your gonna have ATLEAST 1 resonator.
its when you dont have any resonators that it gets loud as HELL..
Reply #17December 10, 2010, 02:15:56 pm
jseeley
  • 106
« Reply #17 on: December 10, 2010, 02:15:56 pm »
I didn't mean a muffler with a turbine inside  :P I mean a muffler that has a straight through design; One that is meant for use on cars that have turbos were minimal added back pressure is desired.
« Last Edit: December 10, 2010, 05:14:49 pm by jseeley »
Reply #18December 10, 2010, 09:33:26 pm
belchfire
  • 140
« Reply #18 on: December 10, 2010, 09:33:26 pm »
You might consider a copper pipe "T" for a splitter. Heater hose stands up to hot glycol so it might work here.
The Owl of Minerva flies at dusk
'81 rabbit pick up  1.6 turbo diesel  SVO
Reply #19December 10, 2010, 09:50:56 pm
wolf_walker
  • 1205
« Reply #19 on: December 10, 2010, 09:50:56 pm »
Call the dealer?  I think I bought one of those a year or so ago for $25 or so.
Mentat Text Two
Reply #20December 11, 2010, 10:34:54 am
« Reply #20 on: December 11, 2010, 10:34:54 am »
a turbo muffler:
the exhaust still has to go from one side of the muffler, to the other side of it, it enters one tube, exits the other..
they really arent all that good of a muffler in terms of flow capability..
magnaflow mufflers are decent.. stainless, and straight thru. flowmasters also work decent.
Reply #21December 11, 2010, 02:08:15 pm
Rabbit TD
  • 840
« Reply #21 on: December 11, 2010, 02:08:15 pm »
I would just make one from some copper fittings (tees and elbows) and some hose close the fitting size and some hose clamps.  I made those wierd bypass cooling hoses for the T/D engine that way and it's worked for 2 years now.  It doesn't take anythnig special for that breather hose.
