Author Topic: ALH gutless after hard run(CAR NOW GOES INTO LIMP)SOLVED!!!!  (Read 34795 times)
Reply #30February 05, 2011, 10:02:10 am
catlin_cava
  • 1954
Re: ALH gutless after hard run(CAR NOW GOES INTO LIMP)
« Reply #30 on: February 05, 2011, 10:02:10 am »
That's strange that your boost reading are in psi and not mBar . Maybe i never used my vag-com to check boost. I know in metric it's 1900-2100 mBar. Do the conversion maybe?
Yea I converted it,
I was getting readings as high as 2500mBar
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #31February 05, 2011, 12:13:38 pm
« Reply #31 on: February 05, 2011, 12:13:38 pm »
The other thing to note (which you may be factoring in already?)  is that the MAP, and hence VCDS, reports absolute air pressure rather than relative.  So, when you're thinking in terms of "boost" you need to subtract local barometric pressure... something in the neighborhood of 14.5 psi, depending on altitude and local weather conditions.
IIRC the troubleshooting info in the Bentley does in all in absolute, just to avoid confusion.
Reply #32February 05, 2011, 12:36:11 pm
catlin_cava
  • 1954
« Reply #32 on: February 05, 2011, 12:36:11 pm »
I might of messed up the calculations but the Problem is solved...N75 valve is cracked and the Vacuum line is busted
Catlin
Reply #33February 07, 2011, 04:25:39 pm
catlin_cava
  • 1954
Re: ALH gutless after hard run(CAR NOW GOES INTO LIMP)Solved!!!!
« Reply #33 on: February 07, 2011, 04:25:39 pm »
It was the N75 Valve that was acting up, I replaced it and the Vacuum line going from the Turbo to it and put the VAG COM on it and took it for a spin, at 3000RPM in 3rd then going WOT the Boost stayed in within Spec :D
Catlin
Reply #34February 08, 2011, 06:00:42 am
  • 1739
Re: ALH gutless after hard run(CAR NOW GOES INTO LIMP)SOLVED!!!!
« Reply #34 on: February 08, 2011, 06:00:42 am »
enjoy the return of all that torque
