Author Topic: High cost of Heat shields  (Read 10054 times)
Reply #15October 11, 2010, 12:14:40 pm
lovinthedeez
  • 489
Reply #16October 11, 2010, 12:22:02 pm
madmedix
  • 204
Re: High cost of Heat shields
« Reply #16 on: October 11, 2010, 12:22:02 pm »
Those have to be the scariest looking heat shields I have ever seen. What the hell were they pressed from, recycled zippers?
'90 TD Jetta
Reply #17October 11, 2010, 12:46:46 pm
rs899
  • 647
« Reply #17 on: October 11, 2010, 12:46:46 pm »
Recycled "Quotations from Chairman Mao"
To be honest, unless I really think ahead, I just reform and reuse them.  The metal is malleable, and as long I get the original shape such that compression of the injector gets the nozzle hole covered, I don't see the harm.
« Last Edit: October 11, 2010, 12:49:57 pm by rs899 »
Reply #18October 11, 2010, 01:40:43 pm
Alcaid
  • 549
'10 VW Passat 1.6TDI Highline
Reply #19October 11, 2010, 02:40:21 pm
sprstu
  • 99
« Reply #19 on: October 11, 2010, 02:40:21 pm »
$125is way too expensive. I've got a set you can have for $50 shipped :)
Mk1 caddy TD, mk4 Golf Tdi
Reply #20October 11, 2010, 02:53:47 pm
dankcorey22
  • 379
    Cummins!
    • Anything that runs
« Reply #20 on: October 11, 2010, 02:53:47 pm »
Here ya go: http://catalog.importrp.com/item.wws?mfr=ELRING&sku=MBZ020779&source=GOOGLEBASE
Are those cheap china made replacement parts? There alful cheap. but not at cheap at prothe  ::)
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #21October 11, 2010, 05:36:54 pm
macka
  • 957
« Reply #21 on: October 11, 2010, 05:36:54 pm »
I can go to my friend at the shop and get a price on OEM for you MTM. If need be we can make a swap, I want some UK parts, you can definitely get cheaper then I can.
Quote from: Vincent Walden
Reply #22October 12, 2010, 07:10:16 am
lovinthedeez
  • 489
« Reply #22 on: October 12, 2010, 07:10:16 am »
Is it really a good idea to recommend Prothe parts?  ::)
injection pumps.....no
turbos......no
door handles....maybe
dollar heat shields.....yup
lots of his parts have questionable backgrounds, which I will never buy certain things.  But a heat shield is a heat shield.   ;D
Reply #23October 12, 2010, 07:57:12 am
Alcaid
  • 549
« Reply #23 on: October 12, 2010, 07:57:12 am »
Anyone tried those Prothe heatshields? A dollar heatshield will cost you more than a dollar if it doesn't seal against the injector...
Reply #24October 12, 2010, 09:02:18 am
Settings
  • 52
    Hudson, QC
« Reply #24 on: October 12, 2010, 09:02:18 am »
There's no debate in my mind.
88 cents per Meyle heat-shield locally...
Seems the OPs website has been updated to 0.76 pounds. That's more like it.
1993 AAZ Jetta ~280k
Reply #25October 12, 2010, 10:39:36 am
« Reply #25 on: October 12, 2010, 10:39:36 am »
I've run them in my engine for a while with no ill effects.  They seemed to seal fine.  I don't have them in currently as I changed injectors, but there was no sign of heat shield leakage when I pulled the injectors.
Reply #26October 12, 2010, 07:06:53 pm
« Reply #26 on: October 12, 2010, 07:06:53 pm »
I like to reuse my heat shields, because I can't afford new ones, each time I check my injectors.
Let us know how long your engine run until the injector tips are fried.
Sorry but they're actually selling anal penetration without lube on that deal. Those shields cost about $1.25/ea.
i've reset a couple heat shields with no issues, and i know a guy that always resets them, and he works on a lot of diesels for himself and other people,  either way for what they cost i always replace them now
Reply #27October 12, 2010, 07:50:50 pm
Mark(The Miser)UK
  • 1557
« Reply #27 on: October 12, 2010, 07:50:50 pm »
Nice to see Simon updated his site. Had I not needed to become a member to post, I would have whispered in his shell like ;D.
I find it funny how some of you didn't catch on that is was clearly a mistake, as that was the price each.
However, this thread was spoiled by those purveyors of doom, whose whole life seems dedicated to spending money unneccessarily. I know shields are only a few $ each, but from recommendations I see elsewhere, any opportunity to throw money away is taken with zeal.
As for frying my injectors due to reuse of shields, I find in my experience that to be utter nonsense. ::)
Any shield that is 'leaking' fluids will soon dislay the fact by continual bubbling and sweating around the base of the injector. Occasional inspection will soon discover this, and if neglected... Well, you only have yourself to blame if you carbon up the threads. If you r &r injectors, any temporary leaks should dissappear after a few days, if they don't, then r & r them again. ::)
I suspect that many stuck injectors have virgin shields beneath them.
I have just adjusted my injectors. They came out easily. Here is a pic of the dryness.
These injectors had been in for about 20000 miles and the shields have been in for about 30000, and date back to the previous Quantum the engine was in.
They have been reformed:
1) 10000 miles into my ownership of the prev car, as I had a headgasket blow, and I skimmed the head by hand.
2)  I had a spare set of injectors from a scrapped Quantum and swapped them in to see if they were any better.
3)I got my first pop tester, and wanted to check it's operation. So I pop tested my 'then' collection of 8 injectors and put in the 4 nearest to 155bar.
4) Physics and H Ricardo convinced me that 130 bar injectors should give better economy than the TD rated ones, so I installed these current Bosch ones from some kind of Ford. They have made in France on them and the nozzles are SN0 315's also French.
5) As part of my recent dramatic re-ring of this indestructible mech headed engine, I have now aligned the pressures from 125, 125, 125 and 130 so that they are all 145bar, as near as I can get them with my homemade spring steel shims.
So that is at least 5 documented reuses, (There may have been a couple of others when I tried to find the knocking  noise, that plagued this engine)
The August rebuild revealed the over zealous skim had allowed the exhaust valves in #1 and #4 to harmlessly dig a nest into the piston crowns ;D
I have a few rules when reusing the shields:
I use the best IMO technique to reform them. Some hit them and some use a drill press, but I use locking grips, that I can select the amount of reforming, and make it repeatable and precise:
About 15 thou clearance on nozzle is sufficient:
Please excuse my dirty thumbnail, I don't bite them [I use it as a gouge/screwdriver though]
I usually set my injectors back in the head with about 30 lb ft. I find that is sufficient if the shield is working correctly. More is damaging IMO to the aluminium ledge in the head...
I keep the shield in the same hole. Prothe's gold shields show the ridges in the under part of the shield . These are often uniquely placed and actually dig a furrow into the head. Many diferent shields will dig different trenches and wear away the flesh [IMO]
Finally for all those clever sceptics out there, here is a little puzzle. Below is a picture of 8 shields. 4 are my ones from above and 4 are presumably single use. The crud on some is where I dropped them into the dirt. They are in no particular order, other than darker ones at the bottom.
So which are the ones that should be frying my injectors?
« Last Edit: October 12, 2010, 08:01:45 pm by Mark(The Miser)UK »
Mark-The-Miser-UK
Reply #28October 12, 2010, 09:04:43 pm
RadoTD
  • 513
    Stage WTF
« Reply #28 on: October 12, 2010, 09:04:43 pm »
Dare you suggest that something on the intrtowebs is incorrect? He surely must have just recently found a cheaper supplier because nothing on the internet is ever wrong...
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #29October 13, 2010, 03:53:13 am
rs899
  • 647
« Reply #29 on: October 13, 2010, 03:53:13 am »
Mark-
Thanks for sharing your technique.  That looks far better than what I have been doing- giving them a whack with a hammer on a round-headed screw clamped in a vise.  I have 11 cars so I have better things to waste money on than injector seals ( like tires, batteries, insurance).
Rick
