Author Topic: 1.6d making too much noise, scary loud. *Now with Video!  (Read 10190 times)
Reply #15September 01, 2010, 05:45:26 am
wil892
  • 216
Re: 1.6d making too much noise, scary loud. *Now with Video!
« Reply #15 on: September 01, 2010, 05:45:26 am »
+1 on the waterpump. I've just replaced mine and the engine is quieter now when its idling, sounds smoother.
Will
1991 Golf MK2 GTD
Reply #16September 01, 2010, 10:10:34 am
sprstu
  • 99
« Reply #16 on: September 01, 2010, 10:10:34 am »
The water pump is only s few thousand miles old, it may be Chinese though so it could be dead. I will be pulling the motor to replace engine mounts and a clutch and PP upgrade so I guess I will pull the WP out as see whats up there as well.
Thank you all for the ideas.
Mk1 caddy TD, mk4 Golf Tdi
Reply #17October 10, 2010, 02:30:36 pm
sprstu
  • 99
« Reply #17 on: October 10, 2010, 02:30:36 pm »
I forgot to update this, sorry.
The problem was pressure plate. Who would have thought reusing stretch-bolts 2 times would cause a problem!? Yeah, turns out when you do reuse them they tend to back out of the crank and cause a terrible vibration that in turn starts to back out all the other bolts in the engine bay. New 210mm pressure plate, clutch, flywheel and all bolts, problem solved.
