Author Topic: what small diesel cars/trucks came with cast iron heads?  (Read 23380 times)
Reply #15August 07, 2010, 06:15:41 pm
maxfax
  • 2126
Re: what small diesel cars/trucks came with cast iron heads?
« Reply #15 on: August 07, 2010, 06:15:41 pm »
I gotta say, I love my 6.5..   Other than some fuel system bugs it's been working great..   And sitting side by side with an Olds 350 gasser not a huge difference dimensionally...
Merc diesel is the way to go..  They're still fairly cheap and plentiful.  ANd parts are cake to find.. The only hangup I've encountered with putting them places other than a Merc is the oil pan configuration..  The sump is towards the front of the engine.
Reply #16August 08, 2010, 11:02:03 am
« Reply #16 on: August 08, 2010, 11:02:03 am »
i was worried about the sump. but i guess i can always cut the pan up, and make a new one..
another thing, how easy are the pumps to work with?
and whats the max rpm on these things? not 6k like a vw i imagine?
Reply #17August 08, 2010, 11:38:18 am
MJF
  • 581
« Reply #17 on: August 08, 2010, 11:38:18 am »
There is not that much more fuel available with home made mods. Inline pump is not as simple as VE pump. Mynädiesel modify the best Mercedes pumps. 4-valve engines revs high, 6000+ horsepower peak, 2-valve engines a little less.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #18August 08, 2010, 05:23:01 pm
« Reply #18 on: August 08, 2010, 05:23:01 pm »
wait, you can get a 20v 5 cylinder? how hard are those to come by? or did i misunderstand you?
Reply #19August 08, 2010, 07:31:34 pm
MJF
  • 581
« Reply #19 on: August 08, 2010, 07:31:34 pm »
Yep, thats om605. Easy to find here, no idea how it is there.
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #20August 09, 2010, 10:57:35 am
« Reply #20 on: August 09, 2010, 10:57:35 am »
what do they come in? im thinking that the 4v engines were more of a europe thing, or i just never paid much attn to mercedes diesels...
Reply #21August 09, 2010, 11:48:31 am
MJF
  • 581
« Reply #21 on: August 09, 2010, 11:48:31 am »
It first came in w124 E-class in ~93 (non turbo) Turbo engines are in w210 E-class and w202 C-class.
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #22August 20, 2010, 01:07:32 pm
honda_is_the_best
  • 104
« Reply #22 on: August 20, 2010, 01:07:32 pm »
they are just too new then. im looking at engines from late 70s/early-mid 80s pretty much, as i dont have a big budget.. and the old stuff is all i can afford.
VW it aint just a car, its a way of life..... Boost, Soot, Repeat
Reply #23August 27, 2010, 02:21:35 pm
« Reply #23 on: August 27, 2010, 02:21:35 pm »
what came in a W123?
Reply #24August 27, 2010, 03:27:12 pm
MJF
  • 581
« Reply #24 on: August 27, 2010, 03:27:12 pm »
om617
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #25August 27, 2010, 05:30:17 pm
« Reply #25 on: August 27, 2010, 05:30:17 pm »
they are cast iron headed right?
Reply #26August 27, 2010, 07:03:44 pm
MJF
  • 581
« Reply #26 on: August 27, 2010, 07:03:44 pm »
Cast iron, non-crossflow head.
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #27August 28, 2010, 12:03:50 pm
« Reply #27 on: August 28, 2010, 12:03:50 pm »
thats probably all im going to be able to afford. only kinda cars i can easily get my hands on are late 70s to mid 80s 240d's and 300td/sd's
anyone have a measurement on a 617 to see how long they are? i guess i should make sure its gonna fit before i get commited..
Reply #28August 28, 2010, 03:37:42 pm
maxfax
  • 2126
« Reply #28 on: August 28, 2010, 03:37:42 pm »
I have a headless one sitting in my garage!!!  From the very back where the trans bolts to the tip of the water pump looks to be about 31"  ..   1.25" of that is an aluminum plate bolted to the back of the engine..  Sort of an adapter place I guess you would say...  Those measurements are a hair to the plus side of things, I gotta hoof a head out of the way to get more precise measurements.. When I get some extra hands I can get you something more accurate...
Reply #29August 28, 2010, 04:31:47 pm
« Reply #29 on: August 28, 2010, 04:31:47 pm »
SWEET, thanks..
can said adapter plate be taken off? or is it kinda important? cause im gonna need to make an adapter to some other kinda transmission..
