Author Topic: Vehicle Inspection Ticket  (Read 8201 times)
Reply #30August 28, 2010, 03:06:42 pm
Re: Vehicle Inspection Ticket
« Reply #30 on: August 28, 2010, 03:06:42 pm »
i had the same problem on my mk1, hopefully this helps you, but i kept blowing the fuse and the light was dim then when youd turn on the turn signal itd get brighter, but the flashers worked fine,  the problem was that i hadn't connected 2 of the wires on the back of the flasher
Reply #31August 28, 2010, 04:08:36 pm
  • 3468
    • McScrubbins Body Wash
« Reply #31 on: August 28, 2010, 04:08:36 pm »
ooooooooo reaaaally. why did you get the inspection.
What about my exhaust? it's straight pipes ...
Reply #32August 29, 2010, 12:11:54 pm
« Reply #32 on: August 29, 2010, 12:11:54 pm »
As long as it's "safe" it should be fine...  IE no holes in the pipes leaking exhaust in to the cabin.
Reply #33August 29, 2010, 04:06:54 pm
  • 3468
« Reply #33 on: August 29, 2010, 04:06:54 pm »
For the record, all my lights have been fixed :)
vanbcguy, thanks for all the info. Very encouraging. I thought my car was going to be pop cans.
