Author Topic: increasing fuel  (Read 7135 times)
Reply #15December 14, 2005, 02:00:39 pm
fspGTD
  • 1529
increasing fuel
« Reply #15 on: December 14, 2005, 02:00:39 pm »
The thermocouple tip from my quick reacting VDO setup:
Jake Russell
Reply #16December 14, 2005, 03:41:04 pm
vwmike
  • 1158
increasing fuel
« Reply #16 on: December 14, 2005, 03:41:04 pm »
Where did you get that thermocouple?
Reply #17December 14, 2005, 04:32:54 pm
Otis2
  • 191
increasing fuel
« Reply #17 on: December 14, 2005, 04:32:54 pm »
Quote from: "fspGTD"
The older VDO "cockpit" pyrometer I have in my GTD autocrosser is very quick reacting.
More recently I installed a VDO "vision" pyrometer and VDO thermocouple setup on a different engine (the VNT Rabbit.)
Jake, since you have easy access to both these vehicles, is there any chance you might experiment by swapping the fast-acting VDO "Cockpit" pyrometer in to attach to the thermocouple installed with the VDO "Vision" pyrometer?  I assume both gauges can be connected to either thermocouple (maybe a false assumption - but it being Xmas and all, and hoping for gifts, I'd like to believe that even the Autometer pyro could connect to any existing VDO TC, too!).
Swapping the two VDO gauges would narrow down the issue as to whether the slowness of reaction time is in the gauge, or in the TC itself.
My own VDO thermocouple is mounted at one extreme end of the  exhaust manifold, so it is only picking up temps from cylinder 4.  I suppose it would have been better to mount it in the middle, immediately prior to the turbo, like you and Veeman have done.  I expect that would give a better "averaging" of all 4 cylinder exhaust temps, but it's too late to change it now.  (That's another reason I'd like to believe the Autometer gauge can connect to the VDO TC).
Reply #18December 14, 2005, 04:57:44 pm
fspGTD
  • 1529
increasing fuel
« Reply #18 on: December 14, 2005, 04:57:44 pm »
Otis2: As I understand it, you can mix and match different brand thermocouples and gauges no problem.  AFAIK all the ones used to measure automotive-application exhaust gas temperatures are all the same types and therefore are electrically compatible.
I could indeed temporarility swap the cockpit gauge into the VNT Rabbit to see if the gauges respond differently, but I probably won't get to it anytime soon since both pryometers setups are working adequately and I've got a lot of other projects on my plate that are higher in priority.
VWMike: I think bought the VDO thermocouple from Seattle speedometer several years aho, but I think they went out of business for a while now.  I found a great VDO supplier/distributor in Seattle, Blanchard Auto Electric, that I get my VDO stuff from nowadays.
Jake Russell
