Author Topic: Transmission Question ID  (Read 6045 times)
Reply #15July 07, 2010, 06:37:30 pm
Re: Transmission Question ID
« Reply #15 on: July 07, 2010, 06:37:30 pm »
my 4A equipped 84 car will blow the doors off my 5 speed AUG equipped 81 rabbit. pulls harder. alot harder. i prefer the 4 speed now that ive had more than just GC's.
whats a shift plate? i never had to change one? i used half of a 4 speed and half of a 5 speed link setup on my 81..
Reply #16July 07, 2010, 08:57:49 pm
Baron VonZeppelin
« Reply #16 on: July 07, 2010, 08:57:49 pm »
On a highway cruiser kind of daily driver, i'd stick with the 4speed if its a 3+E /4A type geared unit. Same overall final drive as most 5speeds. Less shifting (shoulder, elbow and clutch might last longer) and no labor or extra expenses doing a swap.
IF you do swap - minimum you'll need the shifter rods and shifter relay ball for 5spd. And if there is a diff engine mount application - probably that too.
Sometimes the shiftplate/shiftbox that bolts into floor can cause interference going into 5th cleanly - is what GB is talking about. But the 4spd shifter 'can' be modified if that problem presents itself. I had to modify mine. But would likely have a problem if i wanted to run the factory underbody shiftboot due to the mod.
PO did the swap - i just did the tweaking.
Seems like i remember scirroco.com having some of the codes/applications wrong. Cross-reference with tranny listings on www.a2resource.com to be sure what tranny code and date code is what.
Reply #17July 08, 2010, 11:02:41 am
RustyCaddy
  • 395
« Reply #17 on: July 08, 2010, 11:02:41 am »
i haven't done the governor mod...think that really helps at higher rpm so i wonder if that kicks in better with the 5 speed but 3rd gear in a 4 speed might work pretty well with the gov mod to (i need to do that).
The 4A looks like it is ratio-ed about the same as the GP anyways
Reply #18July 09, 2010, 10:50:24 am
rumbling_caddy
  • 80
« Reply #18 on: July 09, 2010, 10:50:24 am »
   If my 4 speed had good gear ratios I would have kept it.  It wasn't and I just finished a 4 speed  GN to 5 speed ACH swap.  It turned out very well and I happy with the outcome.  For the tranny mount I replace the bracket with a 5 speed version.  I used the stock 4 speed linkage but replace a few parts with a few Mk1 Neuspeed shifter pieces  (lever w/ ball, relay shaft, selector lever, both rods with the plastic ends).   There is some 5th gear interfence.  So to go into 5th gear, I push down before going over an up.   My caddy feels much better now and I can cruise comfortably on the freeway :)
Reply #19July 09, 2010, 11:03:02 am
« Reply #19 on: July 09, 2010, 11:03:02 am »
4A and GP are geared exactly the same. and 3rd gear is my favorite gear with a turbo and a gov mod.. it just pulls and pulls, till about 90 mph
Reply #20July 09, 2010, 05:21:16 pm
ffgb
  • 244
« Reply #20 on: July 09, 2010, 05:21:16 pm »
Well, I just looked under my 1981 vw, it has a GP code transmission.  Here is something interesting, my 1984 1.6N/A, bored .020 over with governor mod, lightened flywheel, 4A transmission, with p195 60 R14 tires pulls hard through gears up to 60-65mph.  My stock 1981 vw 1.6N/A with GP transmission and p175 70 R13 tires is really slow to 60mph, but has a higher top end then my 1984.  My 1981 can go to 80-83mph, my 1984 seems to barely top out at 73-75mph.
Reply #21July 09, 2010, 07:50:44 pm
GEE-BEE
  • 1604
« Reply #21 on: July 09, 2010, 07:50:44 pm »
At 75 mph cruise: 7psi, 675 on the egt gauge
195-50-15
I replaced all the boots with a new linkage and 5 speed plate ( floor )when I did he swap
The 5 speed trans mount ( lh front ) is still being made in South Africa VW
Iam building another 5speed with LSD and have all new  s/s 12 point ARP bolt's for the case, I havent decided on color: Black or silver Powdercoating
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #22July 09, 2010, 08:41:30 pm
Baron VonZeppelin
« Reply #22 on: July 09, 2010, 08:41:30 pm »
...5 speed ACH swap. There is some 5th gear interfence.  So to go into 5th gear, I push down before going over an up.
Thats the same tranny code that was put into my 81 Truck.
It does a good job.
Underneath vehicle, the shifter box has a protruded metal edge (about 1/2") all the way around. Put into 5th and have a look under there. The shift lever fork is more than likely hitting into it.
I made relief cuts in the protruded edge where needed and bent the edge down flat. Works great/easy after doing that.
But there is an underbody shift boot that is supposed to mount on that same protruded edge. It "might" compromise how well that boot would fit if you were going to use one. Most are gone, and never replaced.
My 82 Truck has GN 4spd. It will have to be swapped if i keep it.
Reply #23July 10, 2010, 09:23:12 am
« Reply #23 on: July 10, 2010, 09:23:12 am »
my 84 w/ 4A would do 100 mph in basically "stock" form. a slightly bigger air intake and a glass pack are not performance mods in my books. it takes a very long time to get it going 100 without boost, but its possible. now it goes 100 very easy, a little boost goes a long ways.
Reply #24July 10, 2010, 12:09:04 pm
ffgb
  • 244
« Reply #24 on: July 10, 2010, 12:09:04 pm »
Is the gas mileage the same, less, or more now that you have boosted?
Reply #25July 11, 2010, 06:40:51 am
« Reply #25 on: July 11, 2010, 06:40:51 am »
Tyler says that there is no way to get better mileage WITH a turbo. and honestly, i doubt i get better mileage, because im always in the boost pretty heavily. but if i were on a road trip, i would imagine i would get slightly better mileage, because i dont have to pour a black as night cloud going up hills. now i just idle up hills, maybe 2-3 psi boost.
