Author Topic: About to go get my new ride...  (Read 27078 times)
Reply #45June 16, 2010, 10:54:54 am
Re: About to go get get my new ride...
« Reply #45 on: June 16, 2010, 10:54:54 am »
and this thing is either a 12mm engine, or it has gasser bolts in it.. its a 16D and has 17mm crank bolt.. its a 99% chance its a 11mm huh?
Reply #46June 16, 2010, 08:58:21 pm
Baron VonZeppelin
« Reply #46 on: June 16, 2010, 08:58:21 pm »
Yeh, i'd say 99.999
Reply #47June 16, 2010, 09:23:22 pm
« Reply #47 on: June 16, 2010, 09:23:22 pm »
What code is the engine?
Mine is JK, has a 17mm crank bolt and 12mm headbolts. I think it also says 1.6D on the block.
Reply #48June 16, 2010, 09:40:10 pm
Baron VonZeppelin
« Reply #48 on: June 16, 2010, 09:40:10 pm »
79rabbit4dr posted pix of some headbolts in a thread - in FAQ.
Think it is thread about "why do i need expensive head studs in my 11mm block"
11mm gas bolts with tripsquare
11mm diesel bolts with tripsquare
12mm diesel bolts with trips
16D (11) and 1.6D (12) are supposed to be general clues - but maybe not coffin nailing fact.
17mm (11) vs. 19mm (12) is supposed to be coffin nailer.
But i guess ANYTHING can be changed on these cars/engines by now.
And too, maybe we (the general forums of enthusiasts) don't know as much as we had hoped we knew.
« Last Edit: June 16, 2010, 09:42:10 pm by Baron VonZeppelin »
Reply #49June 16, 2010, 09:48:54 pm
« Reply #49 on: June 16, 2010, 09:48:54 pm »
Very true.......I'll double check on the crank bolt but I know I've got 12mm headbolts
Reply #50June 17, 2010, 02:37:50 pm
« Reply #50 on: June 17, 2010, 02:37:50 pm »
my 84 MF turbo engine is a vw rebuild with a 17mm hex bolt. not a 19mm 12pt. and it has 12mm bolts FOR SURE. ive had them out.
Reply #51June 17, 2010, 03:29:59 pm
rallydiesel
  • 1880
« Reply #51 on: June 17, 2010, 03:29:59 pm »
Why are there still no pics? Preposterous.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #52June 17, 2010, 08:53:09 pm
« Reply #52 on: June 17, 2010, 08:53:09 pm »
where is the 100mph rabbit pic!? lol KEVO your lettin us down bromosexual! lolol
Reply #53June 18, 2010, 10:39:06 am
« Reply #53 on: June 18, 2010, 10:39:06 am »
i told you guys, either believe me or dont believe me. i never have my camera in the car. if someone cares, i will take a cell phone pic and txt it to someone, then they can host it. im not going thru that much work to prove a point. it doesnt matter now tho, it has a governor mod and some nitrous oxide. and its fuggin loud..
so, do you guys still want pics? i messed with the government..
Reply #54June 18, 2010, 02:08:04 pm
rallydiesel
  • 1880
« Reply #54 on: June 18, 2010, 02:08:04 pm »
I don't care about the 100 mph thing. I'd just like to see some Rabbit pics baby!!!
Reply #55June 19, 2010, 09:12:13 am
« Reply #55 on: June 19, 2010, 09:12:13 am »
let me go snap a couple..
Reply #56June 19, 2010, 09:51:28 am
« Reply #56 on: June 19, 2010, 09:51:28 am »
Some pics for clix..
there is a header hiding in one of the shots.. and a LOL system in another shot. can you find them?
« Last Edit: June 19, 2010, 10:07:15 am by Rabbit on Roids »
Reply #57June 19, 2010, 12:01:26 pm
« Reply #57 on: June 19, 2010, 12:01:26 pm »
Looks real good........don't you love the reverse lights? :D
Reply #58June 19, 2010, 06:21:27 pm
« Reply #58 on: June 19, 2010, 06:21:27 pm »
is it a rabbit requirement for them to always have broken reverse lights? none of my rabbits have ever had both lenses completely intact..
Reply #59June 19, 2010, 06:32:10 pm
« Reply #59 on: June 19, 2010, 06:32:10 pm »
Wow that's clean. I need to move
