Author Topic: Intercooler  (Read 4197 times)
May 07, 2010, 09:11:51 pm
RadoTD
  • 513
    Stage WTF
Intercooler
« on: May 07, 2010, 09:11:51 pm »
So me and Smokin' Eddy are chatting on facebook and are tossing around the idea of building the greatest intercooler ever.
Here's my idea - run an A/C evaporator in the charge air. Yes, that's right. Air conditioned charge air.
I'm thinking of running sort of an expansion box along my charge lines and mount the A/C evaporator inside it. So, the charge air running across it will nearly freeze.
Thoughts/suggestions? Am I overlooking anything? I've already got an A/C pump in my car, I would just need to run the lines, evaporator and condenser .
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #1May 07, 2010, 09:37:24 pm
Runt
  • 83
Re: Intercooler
« Reply #1 on: May 07, 2010, 09:37:24 pm »
Overkill, and beyond the good kind of overkill, if you ask me.
A good air/water is  adeguate for almost anything.  If you really wanted to do overkill, put in an air/water, then run an evaporator loop in a water chamber to get the water down to near freezing.  I'm not sure how you'd control the king valve at that point though.
Regardless, I think that you'd lose more power running the compressor than you'd gain from the cooling, especially with our weather.  If you are that worried about charge temps, a little water/meth spray will cool the intake nicely, with extra bonuses in power, from what I've read.  This is what I'll be running, once I need it.   ;D
As an afterthought, if you used coolant, not water, you could get the water temps down below freezing. ;)  I've always figured the best way to do air water would be to pull coolant out of the cold side of the rad, back through a  dedicated mini-rad, and then use that coolant in the air/water cooler.  Return to hot side of the rad.
One DD 92 Jetta, One 91 Collision write-off, and One 92 rust free shell, beautiful, stripped, waiting for diesel-ization.
Reply #2May 07, 2010, 10:37:40 pm
RadoTD
  • 513
    Stage WTF
Re: Intercooler
« Reply #2 on: May 07, 2010, 10:37:40 pm »
The point of it would be more "just because" than to build the most logical/proper system.
I see what you mean about using the evaporator to keep the water reservoir for an AWIC cold, but that seems to me to be even more overcomplicated and less efficient. With the evaporator actually inside my charge piping, all of the cold is transfered into my charge air. Keeping coolant cold, I'd be pumping potentially sub zero coolant through lines in a hot engine bay.
I've been toying with the idea of AWIC, but will most likely do either FMIC + water injection or this A/C idea.
Reply #3May 09, 2010, 09:36:48 pm
  • 3468
    • McScrubbins Body Wash
Re: Intercooler
« Reply #3 on: May 09, 2010, 09:36:48 pm »
After a lot of work and expense you'll end up with a net loss of power.  What's the point??
Why would there be a net loss of power?
I think this would cool the charged air a lot more efficiently and effectively than the loss from turning the AC pump.
I think it would have to be tested to be known for certain however...
it's not exactly hard to do either.
Edit: I'd like to add that a FMIC wouldn't be avoided by using an AC condenser. It would run through the FMIC and then somewhere before the intake manifold it would run by the condenser.
« Last Edit: May 09, 2010, 09:47:09 pm by Smokey Eddy »
Reply #4May 09, 2010, 09:58:18 pm
truckoSaurus08
  • 65
Re: Intercooler
« Reply #4 on: May 09, 2010, 09:58:18 pm »
So how would this work? would you be pulling in air from the inside of a car? or some how run all sorts of tubing from the engine bay?
I agree that this would be a complete waste of time and money and the only reason people haven't done it is because it wouldn't be practical.
But hey, theres nothing wrong with a little experimentation so let us know how it turns out. 8)
« Last Edit: May 09, 2010, 10:01:16 pm by truckoSaurus08 »
Reply #5May 11, 2010, 01:53:26 am
OM617
Re: Intercooler
« Reply #5 on: May 11, 2010, 01:53:26 am »
The A/C compressor draws more crankshaft horsepower than the cooler air would support. Thats why it was suggested to chill water, you chill it during low-load times so you have maximum power when you really want it.
Either way its better to just use an ambient temperature water system. A 1amp pump is more efficient to power than a 5hp compressor.
Reply #6May 11, 2010, 06:33:21 am
arb
Re: Intercooler
« Reply #6 on: May 11, 2010, 06:33:21 am »
when my Dad street drag raced in the late 1950's they would pack ice on their intakes before the run. It gave them more power, but did not cost HP due to a compressor load. I think you'd be better off using a IC from something big, like a Dodge cummins - that would be over kill, but look nice out in front of everything.
Reply #7May 11, 2010, 07:00:46 am
Re: Intercooler
« Reply #7 on: May 11, 2010, 07:00:46 am »
Yup... it's gotta... otherwise you would be getting more energy out of the system than you're putting in, and on this forum we obey the Laws of Thermodynamics !!!
The Simpsons - perpetual motion machine & laws of thermodynamics
« Last Edit: May 11, 2010, 07:31:45 am by Vincent Waldon »
Reply #8May 11, 2010, 10:58:43 pm
RadoTD
  • 513
    Stage WTF
Re: Intercooler
« Reply #8 on: May 11, 2010, 10:58:43 pm »
I was completely overlooking the fact that the engine is sucking 300+cfm... The air coming out of vents from A/C can get below zero, but obviously the flow and temp differential are far different.
Now I see what you were getting at, Runt.
Looks like big FMIC + water meth makes the most sense. Glad I've got you guys to keep me thinking straight(er)
Reply #9May 11, 2010, 11:14:08 pm
zagarus
  • 619
Re: Intercooler
« Reply #9 on: May 11, 2010, 11:14:08 pm »
I'll let you guys know how mine works when it's all done
 ;D
Reply #10May 11, 2010, 11:22:44 pm
RadoTD
  • 513
    Stage WTF
Re: Intercooler
« Reply #10 on: May 11, 2010, 11:22:44 pm »
That looks awesome! Please keep updates coming :)
Are you planning to come to any shows in BC?
Reply #11May 11, 2010, 11:29:07 pm
zagarus
  • 619
Re: Intercooler
« Reply #11 on: May 11, 2010, 11:29:07 pm »
Oh ya, I was actually at Spring Unsprung, got a few pics of yer rado :P
Id like to have the coupe done for great canadian.
Reply #12May 12, 2010, 07:54:27 am
TOZOVR
  • 7
Re: Intercooler
« Reply #12 on: May 12, 2010, 07:54:27 am »
Why not just use a water tank setup like the V8 guys... http://www.vortechsuperchargers.com/product.php?p=21
Seen quite a few of these on at the track (New England Dragway as well as NHIS and Lime Rock).  Some gusy run Ice and Water, some a glycol/ice mix or Dry Ice etc.
Or just run an Air to water with a bigger/more accessible reservoir...some screens to keep ice in the tank...
Reply #13May 12, 2010, 09:33:44 pm
macka
  • 957
Re: Intercooler
« Reply #13 on: May 12, 2010, 09:33:44 pm »
Lotus did a charge air cooler in the late 80's but AFAIK it was a water cooler, not an A/C type charge cooler.
Quote from: Vincent Walden
