Author Topic: valve marks in pistons ADVICE NEEDED PLEASE READ  (Read 11377 times)
Reply #15April 28, 2010, 11:18:08 am
hustonr123
  • 124
Re: valve marks in pistons ADVICE NEEDED PLEASE READ
« Reply #15 on: April 28, 2010, 11:18:08 am »
I dont know if every lifter can go bad at once atleast 6 of the 8 valves hit the pistons
Reply #16April 28, 2010, 12:45:29 pm
arb
« Reply #16 on: April 28, 2010, 12:45:29 pm »
This is why I thought it was timing... What did you torque your cam sprocket bolt to after you set your timing ?
Also, I did not see if your head guy tested the compression force of the springs, nor if he took apart / cleaned the lifters. I could see oil contamination / deterioration affecting 3/4 of the hydro lifters all at once (you are sure this is a hydro head ??) There is usually more than one way to fix something :-)
Reply #17April 28, 2010, 01:05:17 pm
hustonr123
  • 124
« Reply #17 on: April 28, 2010, 01:05:17 pm »
i didn't torque the cam bolt but it was plenty tight  i am sure its hydraulic head wish wasn't at this point
Reply #18April 28, 2010, 01:41:03 pm
arb
« Reply #18 on: April 28, 2010, 01:41:03 pm »
Well, unless you were very lucky, your valve timing is not correct. You really should follow the timing procedure in the Bently on setting the timing - it not only sets the injection pump timing but the valve timing too.
Reply #19April 28, 2010, 01:52:23 pm
hustonr123
  • 124
« Reply #19 on: April 28, 2010, 01:52:23 pm »
i have all the correct timing tools  what I ment was i didn't use a torque wrench to tighten cam bolt
Reply #20April 28, 2010, 01:54:36 pm
« Reply #20 on: April 28, 2010, 01:54:36 pm »
where are you in pa
Reply #21April 28, 2010, 02:01:41 pm
Runt
  • 83
« Reply #21 on: April 28, 2010, 02:01:41 pm »
You cannot correctly set the timing belt and tension without loosening the cam pulley.  I'd be surprised if the timing would be out enough to smack valves, but I've never done it, so I don't know how bad it would be.  To install the belt, the crank, and IP pulleys are kept still, and the cam is locked, but the cam pulley must be allowed to rotate with the belt.  once the belt is lined up and tensioned, then the cam pulley is final torqued.
Might I suggest that when you reinstall, you use a little bit of plasticene or better yet plastigage, on the pistons.  Install the head, do the measured torque BUT NOT the angle torques, install timing belt properly, and rotate the engine through at least two full rotations.  Remove the timing belt and the head, and check to see how close the valves are to the pistons.  Plastigage makes it easy, but you can get a pretty good idea with plasticene.
FWIW, I'd get a replacement set of lifters in there just for peace of mind.
Good luck.
One DD 92 Jetta, One 91 Collision write-off, and One 92 rust free shell, beautiful, stripped, waiting for diesel-ization.
Reply #22April 28, 2010, 02:12:52 pm
hustonr123
  • 124
« Reply #22 on: April 28, 2010, 02:12:52 pm »
i loosen the cam bolt every time i just don't torque it to 30 ft pds or whatever the spec is
Reply #23April 28, 2010, 02:15:03 pm
hustonr123
  • 124
« Reply #23 on: April 28, 2010, 02:15:03 pm »
McConnellsburg fulton county
Reply #24April 28, 2010, 02:19:12 pm
truckinwagen
  • 1895
« Reply #24 on: April 28, 2010, 02:19:12 pm »
cam timing could have slipped, without a toque wrench it is hard to say if it was tight enough or not.
83 Opel Kadett Diesel
Reply #25April 28, 2010, 02:29:38 pm
« Reply #25 on: April 28, 2010, 02:29:38 pm »
I usually go past bentley and torque to 45ft/lbs.
Reply #26April 28, 2010, 02:35:24 pm
truckinwagen
  • 1895
« Reply #26 on: April 28, 2010, 02:35:24 pm »
me too, but without a torque wrench it may have only been 25-30 ft-lbs...
Reply #27April 28, 2010, 02:37:57 pm
« Reply #27 on: April 28, 2010, 02:37:57 pm »
arent you supposed to torque the cam to 52 ft lbs?
Reply #28April 28, 2010, 02:40:59 pm
hustonr123
  • 124
« Reply #28 on: April 28, 2010, 02:40:59 pm »
Ill know in about 20 min if it slipped or not  ill post back in a few
Reply #29April 28, 2010, 02:43:17 pm
truckinwagen
  • 1895
« Reply #29 on: April 28, 2010, 02:43:17 pm »
spec is 33 ft lbs if I remember right
