Author Topic: Fuel Leak.  (Read 5283 times)
Reply #15May 12, 2010, 09:00:43 pm
Re: Fuel Leak.
« Reply #15 on: May 12, 2010, 09:00:43 pm »
That seller name brings up nothing GB, maybe you typed it wrong?
Reply #16May 12, 2010, 09:32:06 pm
GEE-BEE
  • 1604
Re: Fuel Leak.
« Reply #16 on: May 12, 2010, 09:32:06 pm »
Moogie2498
search seller
item 220338281895
all new for 59.00
make sure you have the three clips
ONE OF THESE : 360249520706
TWO OF THESE :270574455371
GB
« Last Edit: May 12, 2010, 09:40:40 pm by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #17May 12, 2010, 10:26:11 pm
  • 3468
    • McScrubbins Body Wash
Re: Fuel Leak.
« Reply #17 on: May 12, 2010, 10:26:11 pm »
Human lungs can only just blow up balloons. And the pressure inside a balloon is like 1 psi if that.
Try drinking through 3 straws stuck together, it will be almost impossible.
I wouldn't be surprised at all that you can't blow diesel back into the tank.
Reply #18May 12, 2010, 11:50:07 pm
Re: Fuel Leak.
« Reply #18 on: May 12, 2010, 11:50:07 pm »
If the line isn't actually cracked sometimes you can take a small file to the line end and clean it up a bit.  If the compression nut is overtightened it can mushroom the line, after which it won't seal too well.  New lines will fix it for sure, but I'd try to fix the one I had first personally.
Reply #19May 13, 2010, 07:14:25 am
Re: Fuel Leak.
« Reply #19 on: May 13, 2010, 07:14:25 am »
But i could blow back to the tank. so if i can do it with one psi, there is surely no blockage. lol
Damn I may have over tightened them and muffed it, that kinda crappy news.. well guess i'll have to pull them and see. I'll see if i can't clean up the mating surfaces to get a better seal. thanks
