Author Topic: Need to get injectors tested and adjusted  (Read 2302 times)
April 14, 2010, 08:15:57 pm
boosted_diesel_84
  • 216
« on: April 14, 2010, 08:15:57 pm »
anyone know a good place? i am in Ohio and have 2 sets i need done one set NA and other GTD's for turbo.....thanks for info....
.0020 over block,balanced,blueprinted,8lb flywheel,Stage 2 clutch,ported and ceramic coated head manifolds,turbo,pistons, SS valves, PP 2.5in DP,Intake, 3" ex.GTD nozzles, Built pump, windage tray,36mm pump,ARP Studs.etc.My build thread http://www.vwdiesel.net/forum/index.php?topic=15461.0
Reply #1April 14, 2010, 08:47:38 pm
Re: Need to get injectors tested and adjusted
« Reply #1 on: April 14, 2010, 08:47:38 pm »
A couple of suggestions if you can't find anyone locally:
In the States: these guys in Portland Oregon seem to best reputation on tdiclub.com... guys from all over the lower 48 ship their injectors and pumps there:
http://dfispdx.com/
Haven't dealt with them personally, but most threads lead to them.
However, just a bit north of you in the Great White North are these guys:
http://www.performancediesel.ca/
They do injectors (and have been known to do the odd pump as well ;) ).
Not affiliated with either, btw, but a happy customer of the guys in the Great White North.
