Author Topic: Is it possible to tell 11mm from 12mm head ... if not off engine ?????  (Read 16799 times)
Reply #45April 10, 2010, 03:44:14 pm
doonboggle
  • 179
Re: Is it possible to tell 11mm from 12mm head ... if not off engine ?????
« Reply #45 on: April 10, 2010, 03:44:14 pm »
Not yet.  That comes after the proper tool to extract one is delivered so that it can be determined to be a 11 or 12mm version.
The recess or non-recess I don't believe has been focused on.  In my case, I just want to know what version of bolt I have.
so after all this have we confirmed that 11mm sit above the head surface where as 12mm are recessed in to it? all 11mm and 12mm? or only select few?
doonboggle
1981 Rabbit pickup; 1.6L diesel
2006 Jetta TDI
1971 VW Karman Ghia convertible
Reply #46April 10, 2010, 03:59:17 pm
« Reply #46 on: April 10, 2010, 03:59:17 pm »
same here bro. i just blew a hg.. need to pull the head as well. and order new bolts
Reply #47April 10, 2010, 04:18:05 pm
RustyCaddy
  • 395
« Reply #47 on: April 10, 2010, 04:18:05 pm »
better brains than mine have already commented on this but to me at least one of these bolts looks to have six sides like a hex head???
the hex heads on 11 mm headbolts use a 10 mm allen style bit.
373 F heads can be either 11 or 12 mm apparently (so as to maximize confusion).
i picked up a 10 mm allen head socket at Sears for a 11 mm headbolt and a triple square (for a 12 mm bolt on a different head) and both held up really well...Autozone also sells triple squares but they are really soft.  Sears steel is better (made in USA!)
Reply #48April 10, 2010, 04:45:34 pm
doonboggle
  • 179
« Reply #48 on: April 10, 2010, 04:45:34 pm »
Am presently waiting on delivery of the 8- piece (http://www.restockit.com/8-piece-xzn-set-%28vimxzn100%29.html) kit ordered last nite.
Searched for hours and this one seemed to be the best offer, with qood quality, I could find.
 Did not want all 8 ... but by the time that the 2 I wanted were ordered, and having to pay shipping, would be right at their price almost ... so decilded to go for the whole kitten kaboodle.
Plus, along with free shipping, they also offered an additionsl 5% discount ... and no, I do not own any of their stock ... just posting the order info.
doonboggle
2006 Jetta TDI
Reply #49April 10, 2010, 04:50:39 pm
doonboggle
  • 179
« Reply #49 on: April 10, 2010, 04:50:39 pm »
If you're chatting about my image, they have the 12-point heads.  This was the focus the last couple of days trying to determine the proper removal tool.
TORX was not recommended; I had one also that I initially commented on; and was considering getting the 12-point version of TORX.
Fellows here more knowledgeable than I suggested no go to using it.
doonboggle
2006 Jetta TDI
Reply #50April 10, 2010, 06:24:44 pm
williamtaygan
  • 33
    • Arctic Vegwerks
« Reply #50 on: April 10, 2010, 06:24:44 pm »
I've got a 373F head right here with 12mm holes, and a 373B with 11mm holes AND a 373B with 12mm holes.  Also got another 373F and a 373M ALL 1.6L mechanical heads, but don't have them pulled.  Both the 373B (11mm one) and the 373F (12mm) have recesses for the washers, I've heard the 11mm washers are smaller(?)
If I had to guess I'd say you've got the 12mm head.
1981 1.6 NA Pickup
1982 1.6 NA Westfalia
1990 1.6 NA Jetta (not running)
1991 1.6 eco Jetta
1994 1.6 TD Jetta
Reply #51April 10, 2010, 07:26:01 pm
RustyCaddy
  • 395
« Reply #51 on: April 10, 2010, 07:26:01 pm »
Okay...what would be the #3 bolt in the headbolt tightening sequence looked like a hex head to me.
a friend had a 373 F...i told him it had to be a 12 mm like the Brazilian i have but he corrected me saying it was an 11mm...so go figure.
was the TORX SAE because i don't think that would work like a metric triple square...never had a problem with mine anyways
Reply #52April 10, 2010, 07:59:13 pm
« Reply #52 on: April 10, 2010, 07:59:13 pm »
The casting # and letter on the head means pretty much nothing when it comes to finding out the bolt size and mech or hydro. About 2 years ago we were going to put a table together for the faq and came out with that. Nothing is concrete on what casting # is what. I believe all it can tell you is if the head originally had turbo vavles or not...but I am not certain on that either as it has been a few years now.
Reply #53April 12, 2010, 02:54:50 am
Mark(The Miser)UK
  • 1557
« Reply #53 on: April 12, 2010, 02:54:50 am »
I agree, does look rather 'hexy' to me too ;D
How about a fingerprint of all the bolts [take a white sheet of paper and stuff thumb onto bolts with paper in between ;D]
Mark-The-Miser-UK
