Author Topic: lda springs  (Read 6444 times)
Reply #15March 30, 2010, 02:55:30 pm
410
  • 581
Re: lda springs
« Reply #15 on: March 30, 2010, 02:55:30 pm »
Well, Giles has a spring for me.  I talked to him on Monday so it is on the way.  Now that I have my custom boost pin dialed in, smoke is minimal, honestly!  And power is as good as it was before with heavy smoke.  My biggest problem before was smoke before boost build up.
Anto, did you get a chance to measure the wire dia. of either of your springs?  I would greatly appreciat this info.
Reply #16March 31, 2010, 12:32:45 am
anto
Re: lda springs
« Reply #16 on: March 31, 2010, 12:32:45 am »
Il get a measure on it tonight 410.
Its not noticeably thicker wire.
I take it this is where the added rigidity is?
Can you post a pic of you reworked lda pin?
Reply #17April 01, 2010, 06:04:37 am
410
  • 581
Re: lda springs
« Reply #17 on: April 01, 2010, 06:04:37 am »
anto, I'm working on posting a pic of my boost pin.  I just signed up with photobucket and need to learn how to do this.  Hopefully I'll have time this evening to figure it out.  I've loaded the pics on photobucket but that is as far as I've gone.
Reply #18April 01, 2010, 06:48:42 am
anto
Re: lda springs
« Reply #18 on: April 01, 2010, 06:48:42 am »
Easy after that.
Click on the pic you want to upload and a drop down menu should appear, pick the last link. copy it and paste it into your post and job done. :)
PS il get measurement of spring tonight, bit busy last night.
Reply #19April 01, 2010, 05:33:12 pm
410
  • 581
Reply #20April 08, 2010, 06:01:08 pm
410
  • 581
Re: lda springs
« Reply #20 on: April 08, 2010, 06:01:08 pm »
My new lda spring showed up today from giles shop.  It's silver in color with a wire thickness of .1".  It's .010" thicker than my original spring .  I just put it in before I left work so I haven't had a chance to set it up yet but it is what I was looking for.  Hopefully my results will meet my expectations!  I'm looking for lda control up to at least 14-15 psi.
