Author Topic: A few Questions  (Read 4471 times)
Reply #15March 24, 2010, 08:02:30 am
ShoulderMan
  • 89
Re: A few Questions
« Reply #15 on: March 24, 2010, 08:02:30 am »
Wow,  well, that would be my answer. thank you turbinepowered, it cant get any clearer than that.
   I have a few pictures that i can scan and upload showing the tension bolts used in the 1.2l tdi  i just have to get my scanner working and ill post them.
Reply #16March 24, 2010, 02:27:16 pm
Turbinepowered
  • 1206
Re: A few Questions
« Reply #16 on: March 24, 2010, 02:27:16 pm »
And to add to the joy of the above: A TDI running 19:1 compression with the same 44 pounds of boost would be running an effective 95:1 compression ratio, with ~1400psi cylinder pressure (neglecting heat and valving losses) at TDC.
