Author Topic: YESSSS!!!1!!11! It actually drives!!!!  (Read 7544 times)
Reply #15March 02, 2010, 02:38:20 pm
brandon5
  • 88
Re: YESSSS!!!1!!11! It actually drives!!!!
« Reply #15 on: March 02, 2010, 02:38:20 pm »
Id rather just get it wired up how it is and not spend more dough. And hey my exaughst broke off today so i almost have a straight through!
Sounds Awesome...
Reply #16March 04, 2010, 09:33:56 am
Torchd
  • 372
« Reply #16 on: March 04, 2010, 09:33:56 am »
Whats the power like??
I intend to run a similar setup!
What boost are you running? And when does your turbo spool up?
Reply #17March 04, 2010, 10:27:22 am
brandon5
  • 88
« Reply #17 on: March 04, 2010, 10:27:22 am »
Well i read alot of posts how the t3 is to much of a laggy spool, But i went for it anyways. It spools up really quick, Pulls hard for stock boost (which is like 7-9 for a 1.9?). Ill try and get a video on today, I still have no rad fan and no cluster... :(
Reply #18March 04, 2010, 11:19:19 am
Torchd
  • 372
« Reply #18 on: March 04, 2010, 11:19:19 am »
Hmm.. thats what I heard, Im worried about the spool time too... I want to go all crazy with it.
a 1.9 AAZ with K24, big fmic, giles pump, big oil cooler, straight through exhaust 2.5 in, ARP headstuds, GTD sd274 nozzles and maybe some other tweeks!
So does it spool up at like 2k revs? cuz T3's and K24's in on 1.6s spool at around 3600 revs and thats stupid!
I will be waiting for the vdos..
Reply #19March 04, 2010, 10:25:58 pm
brandon5
  • 88
« Reply #19 on: March 04, 2010, 10:25:58 pm »
Until i have a cluster i cant tell you how quick. But i ran the t3 with my 1.6 before my swap and the spool time is wayyyy quicker. Its really quick stock with a t3. If someone helped me out with how to hook my cluster up ill get a vid.
Reply #20March 05, 2010, 11:38:16 am
Torchd
  • 372
« Reply #20 on: March 05, 2010, 11:38:16 am »
I hope you get ur cluster sorted! Sorry I can;t help with that one!
Reply #21March 05, 2010, 11:13:45 pm
brandon5
  • 88
« Reply #21 on: March 05, 2010, 11:13:45 pm »
No worries. Ill get a video soon. I prolly wont have a cluster so you'll just have to listen and watch haha.
Reply #22March 06, 2010, 06:36:36 pm
brandon5
  • 88
« Reply #22 on: March 06, 2010, 06:36:36 pm »
Ok i tested the rad fan and it works. And ive started to wire up the mk3 wiring to the stock mk2 temp sensor. I also have all my lights working but the cluster... I cant fir the life of me figure out why the cluster isnt working. It lights up, it shows the time and kms driven but thats all. All fuses are good and the wiring is good. What else could it be?
Reply #23March 07, 2010, 10:20:23 am
brandon5
  • 88
« Reply #23 on: March 07, 2010, 10:20:23 am »
I just looked at the wiring for the cluster going to the fusebox and theres a few little plugs missing. Are those for the speedo and such?
Reply #24March 08, 2010, 08:47:56 pm
brandon5
  • 88
« Reply #24 on: March 08, 2010, 08:47:56 pm »
bump
