Author Topic: A Thought on Altenator Exciting  (Read 7708 times)
Reply #15March 06, 2010, 11:09:14 pm
maxfax
  • 2126
Re: A Thought on Altenator Exciting
« Reply #15 on: March 06, 2010, 11:09:14 pm »
Have you tried jumping the D terminal to B+ to see what happens??  That would rule out anything with the alt such as a funky regulator or something..   My bet would be, though, the low voltage at the D terminal is your culprit..  I had similar issue with one of my MK1's years ago..
 Never tracked down the real problem though..  The car was junk and I'm kinda lazy so I ran a switched B+ to a light socket with a 194 bulb duct taped to the dash, then from the socket to the D term...
Reply #16March 07, 2010, 08:12:57 am
somolovitch3
  • 290
« Reply #16 on: March 07, 2010, 08:12:57 am »
Yep, that is what inspired "thought" in first place. Temporally hooked small jumper lead from D+ to Pos on Batt, instant excite at start and kept up 14.3 voltage at idle when removed. New-ish thought, since starter has a terminal to feed ign while starting (on the diesel starter of all things) run a wire thu diode to D+ from there.
Voltage drop in Alt LED circuit....2 volts for the LED, aprox. 9 volts at the 470 ohm LED resister (keeps the 12v from frying the LEDs), and who know on the big (1 watt) resister. And I have 4.8 volts at the D+ term with key on, engine not running. I hate math. ;D
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #17March 09, 2010, 09:35:03 pm
TDDrew
  • 46
« Reply #17 on: March 09, 2010, 09:35:03 pm »
Sweet! Did you try a regular bulb yet? I was thinking about rewiring the light bulb so it would not interfere with the current flow to the alt excitation.  ;D
79 Rabbit 1.6 Diesel 4 door
79 Rabbit 1.5 Diesel 2 door- with a/c, oooooo.
Reply #18March 10, 2010, 06:27:28 am
somolovitch3
  • 290
« Reply #18 on: March 10, 2010, 06:27:28 am »
Not sure how to install one, the LED plugs into the (wonderfull) Circuit Board using it's leads into clips molded into the Circuit Board.
Hard to change that to a lamp setup. And I wonder if there is some reason that VW used a LED any-way, as a diode to seperate circuits?
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #19March 10, 2010, 11:03:52 am
maxfax
  • 2126
« Reply #19 on: March 10, 2010, 11:03:52 am »
I suspected it was just for longevity..  I bulb usually doesn;t last as long as an LED, and on that paticular setup, if the bulb blows it stops charging with no indication to the driver..
Reply #20March 10, 2010, 08:16:58 pm
TDDrew
  • 46
« Reply #20 on: March 10, 2010, 08:16:58 pm »
Ohhhh, what car are you working on? I was talking about my A1. It would be nice to be able to check the volt drop on a good working one.
« Last Edit: March 10, 2010, 08:25:55 pm by TDDrew »
Reply #21March 12, 2010, 05:07:35 pm
somolovitch3
  • 290
« Reply #21 on: March 12, 2010, 05:07:35 pm »
This would be the DumBuny, 1984 GTI Sport (ish). :o
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
