Author Topic: Green engine paint?  (Read 16012 times)
Reply #15February 15, 2010, 12:53:31 pm
Powered by Spearco
  • 1203
Re: Green engine paint?
« Reply #15 on: February 15, 2010, 12:53:31 pm »
All that gasser stuff is JUST FOR MOK UP. Its used to judge clearance of hood, firewall and shift linkage.
Yes its a getto strap, what else would I use for quick checks. The strap is holding up the intake. The pump is mounted to the engine mount plate and yes the block is a gasser one too  :-X.
I don't have another diesel block to use for said clearance's.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #16February 15, 2010, 04:54:25 pm
dash cunning
  • 47
« Reply #16 on: February 15, 2010, 04:54:25 pm »
here is my diesel green, it's a tad lighter than the stock color i think.
79' rabbit 1.5 n/a, 89 golf gasser, 91 jetta gasser, 72 westy.
Reply #17February 15, 2010, 05:22:38 pm
« Reply #17 on: February 15, 2010, 05:22:38 pm »
this is the beautiful detroit green i was talking about!
Reply #18February 15, 2010, 06:05:04 pm
dash cunning
  • 47
« Reply #18 on: February 15, 2010, 06:05:04 pm »
yes sir. found it at checkers auto parts. also dont worry i cleaned up all bolt holes/ sealing surfaces of paint.
Reply #19February 15, 2010, 09:45:51 pm
Turbinepowered
  • 1206
« Reply #19 on: February 15, 2010, 09:45:51 pm »
When I paint a block, I run a short bolt and a washer down tight into each bolt-hole, and use blue painter's tape to mask off the sealing surfaces.
I also have a spare oil pan that's four different colours, since I put that on to protect that sealing surface. :D
Reply #20February 16, 2010, 11:30:41 am
fck
  • 70
« Reply #20 on: February 16, 2010, 11:30:41 am »
http://i5.photobucket.com/albums/y197/Scrochy187/015.jpg
http://i5.photobucket.com/albums/y197/Scrochy187/016.jpg
what paint color did you end up using, and is it available as a spray can, like at an auto parts store?
looks great!
Reply #21February 16, 2010, 01:07:06 pm
Turbinepowered
  • 1206
« Reply #21 on: February 16, 2010, 01:07:06 pm »
Anyone know where I can buy Caterpillar Yellow paint? The guy I'm fixing the Dasher up for is a Caterpillar nut... I think it'd be fun to work up his engine in that colour and not tell him. :p
edit: Be looking specifically for "Old" yellow, or caterpillar colour code C106A, I think.
« Last Edit: February 16, 2010, 01:11:39 pm by Turbinepowered »
Reply #22February 16, 2010, 03:21:40 pm
dash cunning
  • 47
« Reply #22 on: February 16, 2010, 03:21:40 pm »
looks great!
it's dupicolor engine enamel spraypaint. color is detroit diesel alpine green.
also i have a pad i can put on my dye grinder to take the paint of all the surfaces and it's rubber so it doesn't take off any of the metal.
