Author Topic: disc brakes?  (Read 8429 times)
February 05, 2010, 12:19:23 am
parkdog
  • 25
disc brakes?
« on: February 05, 2010, 12:19:23 am »
i need to replace my rear brakes and a buddy has an 85 gti sitting at his acreage just wondering if the disc brake set up would bolt in?
also any suggestions where to get a bentley manual for a 92 1.6td?
Reply #1February 05, 2010, 12:48:44 am
Re: disc brakes?
« Reply #1 on: February 05, 2010, 12:48:44 am »
Given that Canada is one of the largest countries in the world this would be an easier question to answer if you updated your profile to be a bit more specific. ;)
Reply #2February 05, 2010, 09:34:52 am
Re: disc brakes?
« Reply #2 on: February 05, 2010, 09:34:52 am »
you need the right master cylinder and proportioning valve for the disk brake setup.
Reply #3February 05, 2010, 09:41:21 am
Re: disc brakes?
« Reply #3 on: February 05, 2010, 09:41:21 am »
Yuppers... also will need the emergency brake cables as well as the hoses.
Some folks find it easier to just grab the entire axle assembly and swap it across... or you can unbolt from the backing plate, stub axles, etc.
You can cheat and not swap master cylinders and prop valves... lots of folks will tell you they've done it... but VW makes 'em different for disks vs. drums and as a safety system I figure it might make sense to bow to their wisdom?!  Enough cars on the road already with iffy brakes?!  ;)
Reply #4February 05, 2010, 09:43:45 am
Re: disc brakes?
« Reply #4 on: February 05, 2010, 09:43:45 am »
the disk brake master cylinder is ~2mm bigger than the drum brake setup, if i remember right.
Reply #5February 05, 2010, 10:28:55 am
parkdog
  • 25
Re: disc brakes?
« Reply #5 on: February 05, 2010, 10:28:55 am »
well the gti still has all the parts on it so couldnt i just take everything i need off that.
Reply #6February 05, 2010, 11:20:35 am
Re: disc brakes?
« Reply #6 on: February 05, 2010, 11:20:35 am »
yea, that would be the best plan.
Reply #7February 05, 2010, 01:46:44 pm
GEE-BEE
  • 1604
Re: disc brakes?
« Reply #7 on: February 05, 2010, 01:46:44 pm »
25 MM MASTER Cylinder, 16V PROP VALVES
ebay seller : moogie3298 has the ebrake cables
I had to do the Pedal swap from a MK1 to MKII
Hope this help's
G.B.
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #8February 05, 2010, 01:54:03 pm
Re: disc brakes?
« Reply #8 on: February 05, 2010, 01:54:03 pm »
Yup...we're just trying to help you figure out *all* the parts you need to grab.
Reply #9February 05, 2010, 03:49:31 pm
parkdog
  • 25
Re: disc brakes?
« Reply #9 on: February 05, 2010, 03:49:31 pm »
ok sorry im new to this stuff ive never really one anything to a car asides change the oil/rotate the tires.... but ive worked on bikes and small stuff like that.
Reply #10February 05, 2010, 08:13:11 pm
parkdog
  • 25
Re: disc brakes?
« Reply #10 on: February 05, 2010, 08:13:11 pm »
so basically i need everything off the rear main axle, master cylinder,proportioning vavle, and the e-brake cables would it be smart to just  swap the whole brake system from the car or would it be too much work. im guessing they are the same brake setup in the front. but i dont know you guys are the veterans to this stuff.
oh yeah anyplace to order a bentley manual online?
Reply #11February 05, 2010, 09:07:42 pm
Re: disc brakes?
« Reply #11 on: February 05, 2010, 09:07:42 pm »
Chapters/Indigo/Coles carries the Bentley manuals... doesn't look like they have a store in Lloyd but there's one in Saskatoon.  Their web site should let you order them for local pickup.
You can also get them online thru Amazon.ca.
Reply #12February 05, 2010, 09:29:00 pm
  • 2931
Re: disc brakes?
« Reply #12 on: February 05, 2010, 09:29:00 pm »
I swapped the rear discs on my '87 Jetta GLI over to drums.
 Ebrake cables were different but there was no proportioning valves on the master cylinder, like the Sciroccos have.
 The proportioning valve is on the rear beam and didn't need changed.
 Rear discs are troublesome.
 The emergency brake arm gets sticky and they seize.
 New ones are probably OK but used rear calipers are iffy.
Reply #13February 05, 2010, 09:57:34 pm
Syncroincity
  • 727
Re: disc brakes?
« Reply #13 on: February 05, 2010, 09:57:34 pm »
Yup... Just smoked the pads off our '98 Jetta Wolfie. Went from fully functional to worse than useless in less than a month. :P
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #14February 06, 2010, 05:51:49 am
catlin_cava
  • 1954
Re: disc brakes?
« Reply #14 on: February 06, 2010, 05:51:49 am »
germanautoparts.com sells a complete rear disk brake conversion kit. all brand new product.
Catlin
2010 VW Golf City 2.0L "Hers"
