Author Topic: Modifying a 1.6 TD solid lifter block to a Hydraulic block  (Read 10169 times)
May 07, 2004, 05:01:28 am
caddywompus
  • 27
    • http://www.greaseworks.org
Greetings folks,
  I have been lurking on the GTD forum for sometime and finally I have a compelling question regarding my current TD project.  Is possible to modify the solid lifter block by machining the appropriate oil drain hole (this appears to be the only obvious difference) that the hydraulic block has.  I just want to make sure that there are not some other casting differences (like a slightly different water jacket) that would make this idea impossible.  Also, has anyone out there done this??
The problem is I only have a good hydraulic TD head and a solid lifter block.... If someone has a rebuildable TD solid lifter head out there I'm all ears....
Thanks,
Justin
82 Vanagon Westphalia 1.9TDI (1Z)
96 Passat Wagon 1.9 TDI
Reply #1May 09, 2004, 08:49:50 am
caddywompus
  • 27
« Reply #1 on: May 09, 2004, 08:49:50 am »
Yep, it's true, there are turbo chargers whistling on every street corner of the land, each one bringing a smile to my face, and a strong envy to my brain.
I did sell one of my hydraulic heads on ebay, but I came into another one not too long ago.  The solid lifter head from that engine you bid on for me turned out not to be rebuildable due to a severe crack (this from the purported experts up at aluminum head rebuilders in Portland).
Anyhow, thanks for the thread link..... I will check that out momentarily.  When do you want to have that injector rebuilding party??
Justin
Reply #2May 11, 2004, 01:09:50 pm
fspGTD
  • 1529
    • http://home.comcast.net/~vwgtd
« Reply #2 on: May 11, 2004, 01:09:50 pm »
Heh... maybe you and dieseltech should arrange swapping each of your mismatched 1.6lTD heads... swap solid for hydro, so you each get the one you need, and make life easier for the both of you!   :P
Jake Russell
Dieselicious Turbocharger Upgrade/Rebuild Kits
Reply #3May 11, 2004, 06:13:12 pm
dieseltech
  • 129
    • http://www.geocities.com/dean16v/Page_One.html
« Reply #3 on: May 11, 2004, 06:13:12 pm »
sounds good to me! if you want the head its yours just pay for shipping. because i wont need it now!
 i just came accross a free 86 jetta td about an hour ago. the body is hit hard in the rear but motor sounds sweet no smoke ALL ORIGONAL no ***s worked on it and the motor is very clean and only has 102,000mi on it. it was maintained by a very good vw/audi/porsche shop all the recipts are in the glove box from day 1, the car is some old guys car, my friend that owns a bodyshop called me and said the guy told him he could have it, and droped the title off later. the way things work out sometimes is great!!
86 td jetta power everything dd (update off the road for major resto).  97tdi bare bones, DD
and a private junkyard of various other vw/audi/bmw/peugeot/volvo/toyota diesels!!!
Cummins has the worlds record for being the most efficient engine ever!!!!!
for converting fuel into noise!
