Author Topic: MKI Golf/A1 Golf GTD downpipe? did they get made?  (Read 6997 times)
Reply #15November 03, 2005, 03:32:07 pm
Northern RD
  • 167
« Reply #15 on: November 03, 2005, 03:32:07 pm »
Quote from: "DVST8R"
Hot off the press! ok so mabey hot off the welder.  :wink:
MK1 Downpipes.
More pics will be up in the vendors forum shortly. :D
Say, does this pipe need that goofy bracket that sits between the OEM downpipe and the turbo as found on the A1 TDs?? :?  :?  :?
Reply #16November 03, 2005, 04:15:09 pm
vwmike
  • 1158
« Reply #16 on: November 03, 2005, 04:15:09 pm »
That was mainly a support to ensure that the factory flex joint moved. The toilet bowl doesn't flex very well and really needs some help. I don't think it's a concern though when you use a real flex coupling.
Reply #17November 03, 2005, 06:54:01 pm
935racer
« Reply #17 on: November 03, 2005, 06:54:01 pm »
Nope doesn't use that bracket.
Reply #18November 04, 2005, 01:08:45 am
935racer
« Reply #18 on: November 04, 2005, 01:08:45 am »
New finish! Black and heat resistant, this is how they will how up at your door! Who needs a mk2 version? The mk2 versions should be ready for shipment this monday.
http://www.passengerperformance.com/img/mk1downpipe2.jpg
