Author Topic: strange noise  (Read 2163 times)
January 16, 2010, 12:58:13 pm
dieselsmoke
strange noise
« on: January 16, 2010, 12:58:13 pm »
I was driving my 94 1.9 aaz diesel the other day and as I was entering the highway from a yield doing 80 KM/Hr my wheel bearing decided to let go, it popped right out of its housing, and my wheel (passenger side) went all the way out and jammed into the fender. I got it towed home and I had to replace the ball joint and I also had to replace the driveshaft because the ball joint let go and the wheel turned so far out it pulled the inner cv joint apart, the shoulder was still bolted to the tranny flange but the rest of the drive shaft was pulled out. So i got everything put back together and noticed now that my steering wheel sits slightly crooked but the car still drives relativly straight. I am guessing I will need an alignment for that. The problem I have now is that when I am driving I get a slight moaning sound coming from the engine /drivetran area. It only happens when I hit 2000 RPM and it dosen't matter which gear I am in. Would this be a wheel bearing or could this have damaged something in the tranny?? Any thoughts would be helpful. Thanks
Reply #1January 16, 2010, 01:35:23 pm
rabbitman
  • 2788
Re: strange noise
« Reply #1 on: January 16, 2010, 01:35:23 pm »
I would think the tranny's fine, the driveshaft will pull out of the CV joint pretty easily so I really doubt it yanked on anything inside the tranny, unless your driveshaft is held in by a real clip instead of the push together/pull apart type.
The fact that the noise comes and goes with RPM suggests that it is engine/tranny related though, in which case I'm at a loss.
Reply #2January 16, 2010, 02:00:51 pm
veedubcanuck
  • 151
Re: strange noise
« Reply #2 on: January 16, 2010, 02:00:51 pm »
Motor or tranny mount??
2003 Jetta GLS 1.8T w/ Upsolute software 20k kms (yes 20)
1993 Jetta GL 1.9TD stock 440k kms
1990 Jetta 1.6TD stock 320k kms
1993 Golf GL 1.9TD stock 401k kms
1991 Jetta 1.6TD Stock 587k kms
Reply #3January 16, 2010, 04:32:38 pm
Re: strange noise
« Reply #3 on: January 16, 2010, 04:32:38 pm »
does it happen even in neutral?
Reply #4January 16, 2010, 07:34:46 pm
Re: strange noise
« Reply #4 on: January 16, 2010, 07:34:46 pm »
thats what im thinking.
Reply #5January 16, 2010, 09:33:33 pm
dieselsmoke
Re: strange noise
« Reply #5 on: January 16, 2010, 09:33:33 pm »
dosen't happen in neutral. It almost sounds like the moaning sound a wheel bearing makes when it is in the begining stages of diying. I don't think it would be a motor mount since I just put new ones in. It is just wierd that it only happens when it is around the 2K RPM and then nothing for anytime else. I am just hoping that my tranny didn't get damaged since I just had it rebuilt. I am going to drive it for a bit and see if it gets worse or not.
