Author Topic: DGK121 seal kit, wrong front seal?  (Read 9027 times)
Reply #15January 15, 2010, 07:13:29 am
wolf_walker
  • 1205
Re: DGK121 seal kit, wrong front seal?
« Reply #15 on: January 15, 2010, 07:13:29 am »
Seems to be the case.  I'm going to look at the shaft o-ring on my spare pump and see if I can find one
separately or have one laying around maybe.
Mentat Text Two
Reply #16January 16, 2010, 05:17:02 am
« Reply #16 on: January 16, 2010, 05:17:02 am »
So if you get the 121 set; you won't get the cold start o-ring that goes around the rotating cold start shaft,... and you'll end up with a 19mm seal you can't use.
...and if you order the DGK-126 you won't get the LDA o-ring (if you are doing a TD pump),.. and you'll get no shaft seal at all.
It all depends on what style pump you are working on. If it's a pump with fast idle but not an AAZ you will have everything except the fast idle on the LDA and the driveshaft seal
If you have a pump without fast idle you won't have the driveshaft seal and cold start seal
If it's an AAZ you are missing the fast idle on the LDA, the other lever thing that never moves on the LDA and the driveshaft seal.
Reply #17January 16, 2010, 10:47:49 am
wolf_walker
  • 1205
« Reply #17 on: January 16, 2010, 10:47:49 am »
I remember trimming the nubs on the last one I did, thought it was odd.  Is there a pump top with
a wider slot that needed the nubs?
Mentat Text Two
