Author Topic: injection sensor from an AAZ pump used for a revcounter pickup????  (Read 12935 times)
Reply #45January 31, 2010, 06:50:59 am
regcheeseman
  • 714
Re: injection sensor from an AAZ pump used for a revcounter pickup????
« Reply #45 on: January 31, 2010, 06:50:59 am »
The Yellowjacket says that the yellow/white wire is the supply line (+12V) and the grey/white wire is the signal line.
It does? It definitely says 12v feed? Just want to make doubly sure before I toast something. Shame if it is 12V because my PIC controller circuit only has a 5v rail.
I used to  work for Beran designing online vibration monitoring systems for (amongst others) nuclear generating sets, so I've a little experience of interfacing with industrial spec transducers. But all the trans I worked with had the signal conditioning at the amplifier end, not on the piezo transducer.
Oh and you'll find that 4000 rpm produces a 266Hz signal - nothing like 8K ;) - I'm using PWM signals to simulate an engine running for my test bench.
edit: My maths is wrong too.... two pulses per engine rev so that's a 532 HZ signal, thanks for making me go back and double check.
« Last Edit: February 01, 2010, 04:54:46 am by regcheeseman »
Reply #46August 27, 2010, 06:40:41 am
regcheeseman
  • 714
« Reply #46 on: August 27, 2010, 06:40:41 am »
Always the cynic, my intuition told me that the sensor fitted to uk pumps appeared to be a pressure switch with no internal signal conditioning.
I arranged for a friend to meet me at the pub and to bring his wife's unmolested AAZ.
After the anticipated banter for me working in purple nitrile gloves I connected up the multimeter.
5v was present at both terminals with the engine off (also with the ignition off)
Starting the engine and 5v remained on the yellow/white wire but there is now a signal on the green/white wire - I'd guess a 5v square wave. Switch to frequency measurement and it's about 32Hz, blip the throttle sees it rise to 80Hz
So there you go, maybe it's UK specific but it's a normally closed pressure switch fed with 5v
Quite easy to convert this signal to drive a standard revcounter - watch the VNT controller thread....
