Author Topic: loud turbo whine losing oil thru turbo  (Read 11518 times)
Reply #15January 06, 2010, 04:09:15 pm
  • 3468
    • McScrubbins Body Wash
Re: loud turbo whine losing oil thru turbo
« Reply #15 on: January 06, 2010, 04:09:15 pm »
Check to make sure you haven't blown an exhaust manifold gasket. I drove a van that did that once and I was certain that I had blown up the turbo
hmm oh okay that's interesting and a very good point. I have been smelling exhaust a little.
Good thinking Tyler. It will be interesting to try and see :P
I guess i'll find a mirror and a flashlight and look for soot?
Reply #16January 06, 2010, 04:10:37 pm
« Reply #16 on: January 06, 2010, 04:10:37 pm »
Yeah the black soot gives it away, unless your block is caked in oil
Reply #17January 06, 2010, 05:31:32 pm
  • 3468
« Reply #17 on: January 06, 2010, 05:31:32 pm »
I was thinking about that for a bit...
leaking exhaust pressure wouldn't explain the whine...
Reply #18January 06, 2010, 07:29:29 pm
« Reply #18 on: January 06, 2010, 07:29:29 pm »
It might. Exhaust manifold gaskets have a metal backing on them. That metal can/does vibrate and creates a whining like sound. It's worth looking into at least. You might be able to source the leak by revving the engine and feeling for a leak
Reply #19January 06, 2010, 07:46:41 pm
  • 3468
« Reply #19 on: January 06, 2010, 07:46:41 pm »
I've tried that already, no dice.
this is so frustrating. It's got to be a TINY leak somewhere.
the whine sounds a lot like the turbo is overspooling as if it had nothing to work against
... which would suggest a huge leak somewhere....
i took the pipes all off and blew into them, i know my lungs can't even make 1psi but it didn't SEEM to leak from any of the glued joints. The IC didn't seem to leak either. but that is a terribly crude way to tell...
Reply #20January 06, 2010, 07:58:13 pm
« Reply #20 on: January 06, 2010, 07:58:13 pm »
Bypass your IC and see if it still does it.
Reply #21January 06, 2010, 10:06:11 pm
« Reply #21 on: January 06, 2010, 10:06:11 pm »
Find somewhere (like where the boost gauge takes it's reading) and blow 10-20psi into it to find and intake leak.....if you have a compressor and regulator.
Otherwise you can plug the exhaust partways and run it to find an exhaust leak.
Reply #22January 07, 2010, 05:05:37 am
macka
  • 957
« Reply #22 on: January 07, 2010, 05:05:37 am »
Eddy,
       you could rig an electric oil pump and pump air with a compressor through the exhaust turbine and look for leaks. That would show if the seals in the turbo are leaking. That way you at least can eliminate the turbo if its the issue.
Quote from: Vincent Walden
Reply #23January 07, 2010, 01:55:54 pm
rallydiesel
  • 1880
« Reply #23 on: January 07, 2010, 01:55:54 pm »
I think your turbo is on the way out. New whine is never good. I could be wrong though. I think your shaft is unbalanced.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #24January 10, 2010, 04:54:26 pm
toywagen
  • 22
« Reply #24 on: January 10, 2010, 04:54:26 pm »
What about the large diameter o-rings that seal the compressor housing? I had similar situation on a fast drive home from Fort St. John, lots of sound, little boost. Also check turbine housing for cracks.
Reply #25January 18, 2010, 12:42:47 pm
  • 3468
« Reply #25 on: January 18, 2010, 12:42:47 pm »
that gasket, if you can call it that, was totally perished...
just crumbled to bits... was missing in numerous places.
Could this be the culprit?
Ideas for resealing the housing without trying to find the "right" gasket? Could i use card + some grease?
Thanks for the replies.
Reply #26January 18, 2010, 12:53:32 pm
  • 3468
« Reply #26 on: January 18, 2010, 12:53:32 pm »
would RTV silicone hold the pressure? I have some of that ...
Reply #27January 24, 2010, 01:33:54 am
  • 3468
« Reply #27 on: January 24, 2010, 01:33:54 am »
OK so it was leaking around the housing for SURE and leaking from where the exhaust manifold joins the turbo.
I put a very thin film [of RTV] around the compressor housing and a light bead squeezed through when i put it back together, i must say i did a damn fine job.
I then put the turbo back on with a VERY liberal axle greasing of the two mating surfaces to burn a carbon gasket between the two. i have a metal gasket but it's hell trying to get it to stay while im under the car cursing my head off trying to thread the bolts.
All together now and it's boosting like it used to. Chirping the tires on shifts to 2nd.
So assuming the turbo was overspooling can we acclaim that to be the cause of the oil loss?
« Last Edit: January 24, 2010, 01:42:07 am by Smokey Eddy »
Reply #28January 24, 2010, 08:19:05 am
« Reply #28 on: January 24, 2010, 08:19:05 am »
10 more psi, an intercooler, and a little more fuel and they would just be spinning instead of chirping.
and i bet your turbo is probably fine now. just see how it goes.
Reply #29January 24, 2010, 11:12:35 am
  • 3468
« Reply #29 on: January 24, 2010, 11:12:35 am »
10 more? I do have an intercooler.
I mean chirping while just driving normally.
I can spin the tires if i dump the clutch and floor the smoke pedal
