Author Topic: Lift pump...If...and what if....  (Read 14176 times)
Reply #30January 03, 2010, 10:10:16 am
Powered by Spearco
  • 1203
Re: Lift pump...If...and what if....
« Reply #30 on: January 03, 2010, 10:10:16 am »
I just went out and started the truck. It fires right up and then but not even 4sec. after running, it strts to make the noise. Is that because the pressure dif. between the inlet and the pump?
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #31January 03, 2010, 10:34:01 am
« Reply #31 on: January 03, 2010, 10:34:01 am »
tee a pressure gauge into the inlet of the pump, if the noise comes and goes as pressure increases and decreases on the gauge, then that very well might be your problem.
Reply #32January 04, 2010, 03:47:33 pm
AudiVWguy
« Reply #32 on: January 04, 2010, 03:47:33 pm »
Spearco,
Just unplug the pump it will still draw fuel through it. You can check to see if your problem goes away. 8)
Reply #33January 04, 2010, 03:55:05 pm
« Reply #33 on: January 04, 2010, 03:55:05 pm »
Spearco,
that would be alot easier..
Reply #34January 04, 2010, 05:23:20 pm
Powered by Spearco
  • 1203
« Reply #34 on: January 04, 2010, 05:23:20 pm »
Nope no different. But got some 1.9 AAZ injectors to install. Then we'll see.
'13 Golf R:. Tuned
'98 Puch G320
Reply #35January 04, 2010, 07:17:42 pm
« Reply #35 on: January 04, 2010, 07:17:42 pm »
I believe that's due to the internal pressure taking a bit of time to build up.
Reply #36January 04, 2010, 08:16:43 pm
AudiVWguy
« Reply #36 on: January 04, 2010, 08:16:43 pm »
Andrew,
when I experimented with adding the Facet pump to lift for the Giles pump, I felt like it advanced the timing. I got a 4 psi increase in pump pressure on the gauge. Driving it, it knocked more on acceleration than without it. So I quit using it.
What would happen to the timing if I were to enlarge the tiny hole on the return side a few thousands? Anybody played with this?
Cheers,
Jeff
Reply #37January 05, 2010, 07:47:21 am
« Reply #37 on: January 05, 2010, 07:47:21 am »
andrew says it retards the timing tho. and i believe him. (not saying i dont believe you) but he gave an explanation as to why it retards it, and it very well might.
Reply #38January 06, 2010, 04:04:08 pm
« Reply #38 on: January 06, 2010, 04:04:08 pm »
Today we had a VE pump on the bench. It was for an AAZ making 20 PSI. We hadn`t really set anything up yet, just made sure that the max fueling was "close". I forget what RPM we were running, maybe 2000-3000 engine? With the pump being feed with 0 PSI the internal pump pressure was 75 PSI. We turned the feed pump pressure up to 20 PSI and the internal pump pressure rose to 95 psi. Therefore, positive pressure at the inlet of the pump will advance the timing.
I was expecting to see no change since pressure is being applied to both sides of the regulator but I was wrong.
Reply #39January 06, 2010, 06:13:27 pm
« Reply #39 on: January 06, 2010, 06:13:27 pm »
So it looks like all that matters is the pressure difference on each side of the advance piston 8)
Hey Burn, did you happen to see what the dynamic timing did?
Reply #40January 06, 2010, 07:21:32 pm
« Reply #40 on: January 06, 2010, 07:21:32 pm »
You know, I thought about looking at the piston before we started the experiment but once it was in action I totally forgot. Odds are the pump will still be on the bench when I get in in the morning. Maybe there will be time to check it out first thing.
Reply #41January 07, 2010, 07:08:26 am
« Reply #41 on: January 07, 2010, 07:08:26 am »
Just finished testing, there was no change in the advance.
Reply #42January 07, 2010, 09:19:42 am
« Reply #42 on: January 07, 2010, 09:19:42 am »
We cranked it up to around 45 psi when we were looking at the advance. I did see the gauge jump once though. I don't think it changed the actual advance, just jumped. I could be wrong though it was very quick
« Last Edit: January 07, 2010, 09:21:28 am by burn_your_money »
Reply #43January 07, 2010, 10:16:44 am
« Reply #43 on: January 07, 2010, 10:16:44 am »
We share the same thoughts Andrew. Not necessarily needing to have a regulator makes things a lot easier.
Next I want to hook a VE pump up to a flow gauge and see just how much fuel flow (GPH) is required under the most demanding situations. I don't know if I'll be able to do that though because I think it would require modifying one of the test benches
Reply #44January 07, 2010, 03:26:04 pm
wolf_walker
  • 1205
« Reply #44 on: January 07, 2010, 03:26:04 pm »
GPH sounds like something one could test on the (work) bench pretty easily, messily, but easily.
Run it for ten minutes, do the match, etc.  I think.
Mentat Text Two
