AEF head on a 1.6td(SB)?
Topic: AEF head on a 1.6td(SB)? (Read 3375 times)
December 30, 2009, 08:37:26 am
polo_td
December 30, 2009, 08:37:26 am »
As the topic says, can i use the head from the aef engine on the 1.6td (SB) engine?
Is it a straight swap or what do i need to modify?
Head gasket is another issue, can any one tell me what i can use.
thanx
thomas
Sweden
December 30, 2009, 02:32:36 pm
Re: AEF head on a 1.6td(SB)?
December 30, 2009, 02:32:36 pm »
whats an AEF? is it an idi or tdi? how many litre?
December 30, 2009, 03:34:33 pm
December 30, 2009, 03:34:33 pm »
looks like a version of a 1.9 idi n/a
December 31, 2009, 04:32:58 am
polo_td
December 31, 2009, 04:32:58 am »
Correct, u find it in some skoda variants.
Felicia, dont know if its sold in us.
It´s a 1.9l IDI.
with hydrolifters.
thomas
December 31, 2009, 10:07:56 am
December 31, 2009, 10:07:56 am »
if your 1.6 that you are putting it on has hydraulic lifters also, then the head will mate right up. use the AEF (or AAZ, whatever is easiest to get) head gasket also. should be a multi layer metal gasket.
January 19, 2010, 07:17:31 am
polo_td
January 19, 2010, 07:17:31 am »
Hi
Now i´ve started the teardown on the engine.
The block has so much dirt on it what it will take me a week to cleen.
Do you guy´s have any tips n trix how to get this job done easy?
thomas
January 19, 2010, 09:38:13 am
TurboJ
January 19, 2010, 09:38:13 am »
If you haven't taken many parts off the engine yet. I recommend using a degreasing engine wash agent and let it do its work for 10 min or so, then jet wash the heck out of the engine - works surprisingly well. You do have to block all passages into the engine of course, but it's still easier than manual cleanup. You might want to apply a rough brush on the dirtiest spots while the degreaser is working. Spray some more on the tough spots while brushing, and finish it off with the jet washer - that should do the trick.
Jetta II 1.6 TD 'Project 200'
January 19, 2010, 11:52:01 am
polo_td
January 19, 2010, 11:52:01 am »
Brougth it home in boxes sad for me
Just to go manual. boooooooring.
thomas
