Mk3 Gasser to Diesel swap
Topic: Mk3 Gasser to Diesel swap (Read 5149 times)
December 18, 2009, 03:45:25 am
failure
Newbie
December 18, 2009, 03:45:25 am »
My Diesel's being held together with duct tape
what is needed from the body to swap it into a gasser?
Motor
fuel tank?
pump advance cable
speedo
What electrical will i need?
What do i have to yank out of the gasser?
December 18, 2009, 08:54:51 am
akrallysport
Re: Mk3 Gasser to Diesel swap
December 18, 2009, 08:54:51 am »
Which engine are planning on replacing it with? 1.9TD (AAZ) or the 1.9TDI?
*edit: Mind you, you have posted in the IDI forums, so that should be a no brainer...
Last Edit: December 18, 2009, 09:23:06 am by akrallysport
December 18, 2009, 09:10:07 am
failure
Newbie
December 18, 2009, 09:10:07 am »
yup the AAZ
December 18, 2009, 09:25:40 am
akrallysport
December 18, 2009, 09:25:40 am »
What I'm using for my swap (because I had a complete mk3 TD donor car):
- tank
- fuel/diesel lines and filters
- engine (I hope)
- transmission (clutch disc has different splines from a gasser, and different 4th/5th ratios)
- exhaust downpipe to cat (cat-back is the same for both gas and diesel if you keep it stock)
- instrument cluster
- throttle/pump cable (throttle pedal shouldn't need to be changed unless you want cruise control... I'll find out about this over the break as I do some research)
- cold start cable
- engine bay wiring harness
If you're doing a mk3 to mk3 swap, most of the wiring should just be plug and play. The harness makes it easier, but most guys mod them anyways for glow plug wiring mods, etc.
As far as yanking the old gasser stuff out... the entire EFI system and cluster can come out. This is also where you make the decision regarding keeping A/C.
Last Edit: December 18, 2009, 09:27:57 am by akrallysport
December 18, 2009, 09:35:56 am
failure
Newbie
December 18, 2009, 09:35:56 am »
Thanks for the info, whats the glow blug mod all about?
December 18, 2009, 09:47:13 am
akrallysport
December 18, 2009, 09:47:13 am »
http://vincewaldon.com/index.php?option=com_content&task=view&id=30&Itemid=28
I'm going to try a cleaner version of that setup.
Forgot to mention, you can transfer the extra socket/clips on the fusebox, or you can transfer the whole thing over.
Last Edit: December 18, 2009, 09:52:54 am by akrallysport
December 18, 2009, 02:23:04 pm
rodpaslow
December 18, 2009, 02:23:04 pm »
I'm planning the same swap with a 1.6 TD into a 96 gasser. I have a couple of questions
1. are the motor & tranny mounts essentially the same as the MK2, or the Mk3 gas will work with the diesel?
2. Will the serpentine assy work with the injector pump, or will it interfere it?
3. Tranny ratio, I have an extra .75 fifth, will it be fine as long as I change 5th?
thanks for any help!
99' 1.9 1Z Tdi, hybrid pump -1.9 housing & rover internals, 2052 wastegate turbo,.25 hflox nozzles, SDI intake, CTN tranny
96' 1.6 TD Golf, Giles pump, VNT 17, Gas changed to Diesel, Air to Water Int.
December 18, 2009, 03:45:54 pm
December 18, 2009, 03:45:54 pm »
usually mk3s have pretty tall transmissions, theres really nothing wrong with using a short geared one tho. a gasoline tank works fine, i know on mk1s its actually the same tank i have no idea about mk2 and mk3s tho
December 18, 2009, 04:11:15 pm
akrallysport
December 18, 2009, 04:11:15 pm »
The tank itself should be the same in a mk3 (maybe a few vents?), so an alternative would be to swap the in-tank pump with just the fuel level sender unit. Or keep the pump, but I'm not sure how long it will last.
As for the engine mounts, you should be able to use all of the mk3 mounts. Referring to my Bentley service manuals the major difference between diesel transmissions (1.6TD vs AAZ) is the final drive ratio... 3.94:1 vs 3.67:1 respectively. If you can provide us with a transmission code, I'm sure someone can verify the ratios.
