Author Topic: camshaft pulley!  (Read 8884 times)
Reply #15December 15, 2009, 02:29:18 pm
Re: camshaft pulley!
« Reply #15 on: December 15, 2009, 02:29:18 pm »
I've seen about 3 cams that broke because of people using the cam lock to tighten/loosen the cam. One snapped right at the #4 bearing
Reply #16December 17, 2009, 02:59:44 am
Makebeleaf
  • 57
« Reply #16 on: December 17, 2009, 02:59:44 am »
You can get the tool from Princess auto for $15 from Princess Auto. Pretty darn cheap and no messing around!
http://www.princessauto.com/tools/auto-repair/auto-repair/8159808-camshaft-holding-tool?keyword=cam+tool
Reply #17December 18, 2009, 03:22:29 am
smutts
  • 720
    ClackClackClackClackClack
« Reply #17 on: December 18, 2009, 03:22:29 am »
Bit of lead flashing to protect the cam lobe, seems easiest.
Reply #18December 18, 2009, 06:35:58 am
« Reply #18 on: December 18, 2009, 06:35:58 am »
My thoughts are:
- if you use the cam lock to to loosen the cam sprocket you will very often get this result:
It's not designed for those forces evidently. ;)
- if done properly, this is safe:
"Done properly" means the wrench is very carefully adjusted so that it's grabbing the sides of the cam lobe rather than the profile that actually engages the lifter.  That way even if a nick results it's not on the part of the cam that pushes against the lifter.
- having said that, the tool on the bottom (as suggested by Makebeleaf) is dirty cheap and works extremely well for all kinds of different sprockets:
I can't imagine taking the risk with any other method... just my opinion.
« Last Edit: December 18, 2009, 06:38:24 am by Vincent Waldon »
Reply #19December 18, 2009, 12:49:49 pm
« Reply #19 on: December 18, 2009, 12:49:49 pm »
I really doubt an adjustable wrench could hurt a cam lobe, that stuff is sooo hard.
I have a junk cam I will smack with different stuff (hammer, screwdriver, punch, chisel yada yada) and see how it takes it.
Reply #20December 18, 2009, 01:13:39 pm
« Reply #20 on: December 18, 2009, 01:13:39 pm »
I smacked one with a hammer as hard as I could once. It was an accident I was using a punch to get out a headbolt and missed the punch :-[ . It did make a mark on the cam, but I ran it afterwards with no ill effects. I could basically see it, but not really feel it, and it was off to the side so it wasn't on the lifter squarely.
Reply #21December 28, 2009, 09:17:53 am
smutts
  • 720
« Reply #21 on: December 28, 2009, 09:17:53 am »
If anyone in experimenting with a knackered cam with a hammer, mind your eyes if the result is shrapnel. ;)
Reply #22December 29, 2009, 11:48:45 am
« Reply #22 on: December 29, 2009, 11:48:45 am »
ok, well, if someone does some valid testing, and the cam doesnt scratch, i will use that method next time i do something up there. i could see it working if you used a wrench with nice clean jaws, and no burrs anywhere to mar the cam, and with it nice and tight against the cam and tightened so it couldnt slip or twist, it seems like it would work fine. i keep forgetting these cams are SUPER hard alloy, probably harder than any tool alloy really.
Reply #23December 29, 2009, 12:50:43 pm
Vanagoner
  • 219
« Reply #23 on: December 29, 2009, 12:50:43 pm »
Please help school me up-  I always leave the cam free and hit a wrench with a brass hammer to loosen it.  I tighten it up that way too when I'm done.  Am I hurting the belt or anything else by doing so?
Sage
