optimize my garett t2
Topic: optimize my garett t2 (Read 4089 times)
October 16, 2005, 12:24:02 am
santou
October 16, 2005, 12:24:02 am »
Hi, i have got a citroen zx 1.9td with pump bosch + 10mm head.
I would like that you help me has to optimize my turbo for most power.
I want being to leave an equivalent flow (~0.15,0.16 kg/s) has that of a garrett T3, while keeping the base of turbo of origin t2.
The pressure must to be lowest possible (0.9b, 1.1b max)
-one possibility
ego I had thought has to change the trim of wheel 60 and a/r casing of 0.48 of the t2 with dimensions compressor. but I do not know if there is a wheel and a casing of with these characteristics.
an other idea?
_________________
lost tv show
October 16, 2005, 01:09:28 am
Maarten
October 16, 2005, 01:09:28 am »
I swapped the T2 on my 1.9TD for a KKK K24 from a 1.6TD, if Citroën has the same optiuons you could do the swap too
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
October 16, 2005, 02:00:02 am
santou
October 16, 2005, 02:00:02 am »
I think that will be possible to assemble a k24 but what frightens me more, it is the work of adaptation of the pipe.
how you proceeded for adapted the turbo one?
_________________
Ford Wiki
October 16, 2005, 03:44:49 am
vwmike
Authorized Vendor
October 16, 2005, 03:44:49 am »
A picture of this setup might help....They don't sell Citroens in the US.
October 16, 2005, 07:54:03 am
Maarten
October 16, 2005, 07:54:03 am »
Are you from france or canada?
If the flanges are the same as on a VW the only problem is the oilfeed/return.
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
October 16, 2005, 08:10:42 am
santou
October 16, 2005, 08:10:42 am »
I am French, you think flanges for t2 is same one that k24?
there is no adaptation has to make for assembled it.
which problem can posed the oil feed and return?
_________________
ATV Specs
October 16, 2005, 08:41:04 am
Maarten
October 16, 2005, 08:41:04 am »
if the flanges are compatible depends on the the manufactorer of the car.. if you can take a pic and measurements I could check my spare turbo.
These guys make flange-adapters but any workshop can do that kind of work for you:
http://www.42draftdesigns.com
I don't know how the oilfeed/return are on you car, only thing I can say that the return was different on a VW. I solved it with a piece of hydraulichose and 2 clamps
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
October 16, 2005, 09:07:25 am
santou
October 16, 2005, 09:07:25 am »
my arrived of oil is on the cylinder head and the return goes directly to the sump.
flange of k14 is a same k24?
_________________
lost season 5
October 16, 2005, 11:52:29 am
Maarten
October 16, 2005, 11:52:29 am »
Can you post some pics?
All VW flanges from that era (1.6TD/1.9TD Garrett T2/T3, KKK K14/K24) are the same, trapezium:
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
October 17, 2005, 08:05:02 am
santou
October 17, 2005, 08:05:02 am »
I know some citroen zx td has turbo k14 , if a k24 is assembled without problem on the pipe of k14, I think of being able cleared up me to find the pipes.
i cant post some pic now, because the accesses to the turbo's place is not obvious, on the other hand I seek a turbo demounting to make photograph, i informe you.
_________________
Healthy Living Forums
