Author Topic: hi i'm new & need help  (Read 2111 times)
November 30, 2009, 10:28:35 am
rishi
  • 5
« on: November 30, 2009, 10:28:35 am »
hi everyone i am new on this forum and new to diesel cars, have bought a mk3 1.9 td ( aaz) and wanted to know how can i tune it up. what are the first steps to take? how do i fit a turbo gauge? and what turbo can i use to upgrade mine? all at low cost ov course as i'm a student  ;D any help would me much appreciated thankyou
Reply #1November 30, 2009, 11:02:28 am
Dirtrag2
  • 298
Re: hi i'm new & need help
« Reply #1 on: November 30, 2009, 11:02:28 am »
welcome aboard!!! always nice to get new diesel enthusiasts  ;D
as for tunning, your engine is also refered to as AAZ ( 1.9 TD ) this should help you in your research...
speaking of wich, there are all sorts of mods you can do cheaply to your engine to make it go faster, look for most of them in the FAQ section. any questions you may have at this stage have most likely been covered so try the Seach function as well... but seeing as you are new here you might try this one first... http://www.vwdiesel.net/forum/index.php?topic=579.0
I'm sure that if you have questions or are uncertain of something we will be able to help you out... oh and pictures are always a cool way to get attention  8)
...Darcy
'97 Jetta 1.9TD ( dirtrag2 )
'88 Fox Wagon ( projekt Dirtrag 3 )
Reply #2December 01, 2009, 09:27:54 am
rishi
  • 5
« Reply #2 on: December 01, 2009, 09:27:54 am »
ok have had a read but dont understand all of it, what about a bigger turbo on the cheap? scrapyard donors?
Reply #3December 01, 2009, 11:39:51 am
GEE-BEE
  • 1604
« Reply #3 on: December 01, 2009, 11:39:51 am »
K14 OR KO3 ?
DOWNPIPE 2.5
GILES PUMP
MCNALLYELECTONICS.COM  EGT/BOOST GAUGE
Intercooler
Gee-Bee
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #4December 01, 2009, 05:24:27 pm
Dirtrag2
  • 298
« Reply #4 on: December 01, 2009, 05:24:27 pm »
what parts do you need help with??
as for the turbo, try to start by identifying the turbo you have... weather it be a K03, T2 or a K14 it should put out at least 18 psi...
...Darcy
