Author Topic: 1.6td Not starting - no fuel  (Read 3774 times)
Reply #15December 11, 2009, 01:22:16 am
Passat_Phil
  • 13
Re: 1.6td Not starting - no fuel
« Reply #15 on: December 11, 2009, 01:22:16 am »
the solenoid is fuel related and the t-stat is a cooling part. If you are looking for a good manual, you can purchase a proper bentley manual online.
Thanks
I know that.. I wasn't sure if the car thought it was a temperature it's not it might stop the fuel cut off opening... however... Checked the fuel cut off solenoid.. that was ok
Got it started after following some old advice of put it in gear and move it to help the fuel through... now it's started
Does this mean it is likely to happen again... knackered pump? or will it just be a blockage in the line that has now shifted?
It seems to be working now though
Bentley?...
« Last Edit: December 11, 2009, 01:52:49 am by Passat_Phil »
