Author Topic: Trouble with 1.6 TURBODIESEL  (Read 4672 times)
October 12, 2005, 06:43:01 am
Mirvis
  • 6
« on: October 12, 2005, 06:43:01 am »
Did anyone have this kind of problem and what is the solution?
The 1.6 liter TURBODIESEL engine iin my 1992 Jetta starts excellent.
15-20  seconds later it doesnt hold idle, shakes violently and can be kept running at middle range speed only. It expells a lot of white and bluish smoke with strong diesel smell. Some time ago it was enough to run the engine in this mode a few minutes and the smoking would disappear together with clicking noise coming or from the pump or from the engine top.
Even warmed up the engine occasionally shakes indicating missing.
About a month ago without any intrusion by anybody, the engine started to run perfect from start on. Now the trouble did return and the engine does smoke at all times. The car still can go 70-75 miles per hour, but some time after start power loss can be felt.
What this engine behavior points to? Any suggestions.
Thanks. Ark Mirvis "THE HEATERMAN"
Many years with diesels and still many questions!
The more I learn, the more I understand how little I know. Ark Mirvis
Reply #1October 14, 2005, 03:29:39 pm
pete
  • 7
Re: Trouble with 1.6 TURBODIESEL
« Reply #1 on: October 14, 2005, 03:29:39 pm »
I think you problem is fuel related pluged filter, (pickup or in line)
Quote from: "Mirvis"
1987 2dr.Jetta 1.6L
1990 Jetta soon to be 1.6L
1992 Golf 2 dr. 1.8L $600.00
1996 GTI Parts car 2.0L
1983 Vanagon westy 1.9L
Reply #2October 15, 2005, 12:59:09 am
Maarten
  • 339
« Reply #2 on: October 15, 2005, 12:59:09 am »
Get it timed properly.. check and replace air/dieselfilter and use a dieselinjectorcledaner like Forté directly in the filter to clean out the injectors (could be one dirty/leaking)
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
Reply #3October 15, 2005, 01:15:46 am
vwmike
  • 1158
« Reply #3 on: October 15, 2005, 01:15:46 am »
Shouldn't this be in the troubleshooting forum?  :)
Reply #4October 15, 2005, 02:12:19 am
Mirvis
  • 6
« Reply #4 on: October 15, 2005, 02:12:19 am »
Thanks, Pete.
I will replace the filter and see.  Ark.
