General Information
General
How do I decipher how much Amps an alt is?
Topic: How do I decipher how much Amps an alt is? (Read 5816 times)
November 22, 2009, 06:10:35 pm
November 22, 2009, 06:10:35 pm »
When i purchased my 91 parts car it came with the alternator that was on the engine (65 amp i presume) and one that came with.. now i am unsure if it is also a 65.. 75.. or a 90? (these are all the ones ive heard floating around).
How can I tell what's what
Also! instead of starting another three line thread lol.. Do 81's come with a oil baffle under the Valve Cover? My 91 has one.. but i haven't taken the VC off the 81 yet.. and want to know if i should throw it in on the next order.
Last Edit: November 22, 2009, 06:17:45 pm by 8v-of-fury
November 22, 2009, 07:17:36 pm
Re: How do I decipher how much Amps an alt is?
November 22, 2009, 07:17:36 pm »
no clue on the alt.s
From the factory I haven't seen an 81 with a cover...take the oil cap off and look
maybe a little off topic...
Round 2
November 22, 2009, 09:14:55 pm
November 22, 2009, 09:14:55 pm »
Lucas, I never thought of taking the cap off
I'm using inappropriate language again - modified by burn_your_money
! found out 81 didn't come with anyway.. gonna steal the one off the 91. found out this thing has 725k kms not the 408k i thought before!
yes your slaughtered cow head is a little off topic.. but sometimes you just have too....
Last Edit: November 23, 2009, 09:34:45 am by burn_your_money
November 23, 2009, 05:00:43 am
November 23, 2009, 05:00:43 am »
" this thing has 725k kms not the 408k i thought before! "
More for less....you can't beat that.
Round 2
November 23, 2009, 09:35:42 am
November 23, 2009, 09:35:42 am »
Cam splash gaurds came out with the use of hydraulic lifters for both the gas and diesel engine
November 24, 2009, 05:34:46 am
November 24, 2009, 05:34:46 am »
anyone on the alt issue? lol
November 24, 2009, 07:44:11 am
maxfax
November 24, 2009, 07:44:11 am »
IF there is still a sticker left on the casing it'll usually be on there, or stamped into the casing somewhere, usually around the sides..
November 30, 2009, 09:50:39 pm
November 30, 2009, 09:50:39 pm »
Look at the alternator connector. IIRC the 90 amp ones have a more heavy duty stud, nut and eye terminal type connection while the lower amp ones have spade connectors that push on. I think all of them are otherwise pretty similar. Also, IIRC the 90 amp alternators came with air conditioned mk2 cars, without a/c you get the lower ampere unit.
General Information
General
