Engine Specific Info and Questions > TDI Engine -General Info
Kia mtdi pump on 1Z
golftd412000:
the .187 it's good for the start not the performance.
take à fiat croma tdid pump it's same body with 20... axe
gigaz2:
if I could find a fiat pump I would use it, but this was the best I could get.
this also has a 20mm axel
I'm thinking about filling the spaces with aluminium (with a TIG) then machining the case to 50mm
blackdogvan:
I think they are very similar to the rover pumps. I machined my aaz pump bracket to accept the larger nose & using ALH pump nose parts everything lined up perfect. I also swapped out my aaz delivery valves as the LR ones were 1cm longer & the injector lines didn't line up.
gigaz2:
thats also a good idea, and safer, I have a few 1.6TD brackets that should fit the 1z, could machine one of those without a problem.
if anything goes wrong, I'll still have the 1Z bracket
lord_verminaard:
What's the Kia application for that pump? Just adding to my list of ebay searches. ;)
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
