Author Topic: changing axle Q?  (Read 7976 times)
Reply #15October 17, 2005, 09:22:42 am
BlackTieTD
  • 1512
changing axle Q?
« Reply #15 on: October 17, 2005, 09:22:42 am »
master acid: as suggested, just pop the axle off the car and do it in a vice or something. it would be more effort than its worth trying to do it in-car, although i'm sure with enough swearing it could be done. this really isn't that hard a job once you get familiar with it. once you do, you can pop off an axle in 5 or 10 minutes with someone helping.
Reply #16October 17, 2005, 10:26:53 am
Master ACiD
  • 328
changing axle Q?
« Reply #16 on: October 17, 2005, 10:26:53 am »
i guess ill go under there and pull the axles then.
thanks guys.
Reply #17July 23, 2006, 01:59:18 pm
Master ACiD
  • 328
changing axle Q?
« Reply #17 on: July 23, 2006, 01:59:18 pm »
i pulled the axles and put it in a vise. gave the outer joint a good wack with a hammer and nothing happens. seems to be stuck or something.
Reply #18August 10, 2006, 05:49:45 pm
irdiver
  • 52
changing axle Q?
« Reply #18 on: August 10, 2006, 05:49:45 pm »
sweet this is just the post i was looking for... i had a brake caliper lock up on me while on the highway, load of fun at 70mph, it toasted most things in there and then looks like the boot cooked split and dumped the nasty grease all over the passenger wheel.  sigh... plus i think the drive seal is leaking anyway, so thanks for all the post info on here it should make my weekend go much more smoothly!
'91 jetta eco diesel - sold 10/06
currently looking for a new project
