Author Topic: SOLD~BUY MY CAR~BUILT!!!! 1.6TD~ SOLD!!!!!!!  (Read 19484 times)
Reply #30April 10, 2010, 10:15:17 am
53 willys
Re: ~BUY MY CAR~BUILT!!!! 1.6TD~
« Reply #30 on: April 10, 2010, 10:15:17 am »
What about taking the oil psi from the oil filter adapter hiusing, I did this for my oil psi/Temp
Mcnally gaugeadapter tee ( 1/8 NPT )screws right in
GB
stay in Touch..
Iam on the list
the isspro oil gauge is only 80psi....oil filter flange mounting it would peg the gauge BAD and probably ruin the gauge and or sender....
Reply #31April 10, 2010, 01:30:22 pm
GEE-BEE
  • 1604
« Reply #31 on: April 10, 2010, 01:30:22 pm »
Ok
is the Title Diesel or was this a gas conversion ?
What about the sunroof and do you still have the a/c condenser ?
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #32April 10, 2010, 07:23:47 pm
53 willys
« Reply #32 on: April 10, 2010, 07:23:47 pm »
It is a conversion....but I had the title changed to diesel before I even registered it for the first time..so it will be easy to register!
The sun roof worked before I took the dash apart..now it just need to be rehooked up.
The ac in this car worked really really good when I had the gas engine in...I took the comp off the 16v and mounted it on the diesel...but have never hooked it up.
The tube on the condensor broke so it will need a new/junk yard condensor and a full recharge to get the ac working.
Reply #33April 11, 2010, 05:14:04 pm
53 willys
« Reply #33 on: April 11, 2010, 05:14:04 pm »
WOW I'm sitting here making a list of all the things I spent money on and bought for this car and it's kinda making me sick :o...haha
now I remember why I don't keep and add up my receipts....I have a PILE of cash into this car :o :o  ...it's a steal at $5,200
I will update with the list soon.....  8)
« Last Edit: April 11, 2010, 05:24:07 pm by 53 willys »
Reply #34April 11, 2010, 05:30:52 pm
« Reply #34 on: April 11, 2010, 05:30:52 pm »
Yeah I know. I hate you a little. I know I have more in my bomb than you are selling this for. Yours is nicer by far...and done. I just wish we could see it run before it goes away, probably never to be seen again ;)
Reply #35April 12, 2010, 11:47:02 am
53 willys
« Reply #35 on: April 12, 2010, 11:47:02 am »
ok here is a list of cash...I mean mods on the car..lol :P
VW list
The good
* rebuilt 1.6td with new everything!
* all new cooling system hose's
* new alt
* all new drive assy belts
* all new fuel lines(return lines)
* new(1500 miles) T3 turbonetics ceramic ball bearing turbo with polished comp housing
* Engineered diesel dual refreance external wastegate (perfect control and best way to run nitrous if you go that route)
* custom ss header with external
wastegate mount
* in-cab boost regulator
* fully built zukgod1 11mm injection pump
* custom mech 1.6TD multi-layer steel headgasket (2hole)
* fully port and polished head
* ARP headstuds
* lightened intermediate shaft
* rebuilt injectors with Bosch DN0SD273 tips
* new pimped glow plugs and wiring
* front bumper mounted alum intercooler
* custom 3" downpipe with wastegate dumping into the bottom (v-band clamps at turbo and flex pipe
* 3" pipe from turbo back with band clamps for easy removal
* clutchnet.com 210mm 24 spline SPRUNG race clutch
* lightened flywheel
* dodge cummins water separator with 5 micron filter
* under hood lift pump gauge
* retained the stock gas lift pump (5-7psi)
* AFE dry cold air intake
* Euro spec GTI alum valve cover powder coated black
* BFI HD oil pan
* block mounted turbo oil drain conversion
* rebuilt heater box
* G60 trans mount
* new diesel front motor mount
* new hydro rear motor mount
* new heater core
* new radiator
* new water pump
* cooler fan switch
* new tstat
* new coolant bottle cap
* passat dual cooling fan setup
* new trans cv seals
* new speedo grommet at trans
* audi tt control arm bushings
* poly front sway bar bushings
* all dash and gauges have blue LED lighting
* DIESEL CLUSTER with TACH!!
* FULL isspro gauge set up- pyro-turbo boost-exhaust back pressure-coolant temp-oil pressure
* two gauge A piller mount
* three gauge 42draft gauge holder
* diesel hood liner installed (these only come on diesel vw's and I found one in great shape!
* STD seatbelt conversion
* I also replaced all the white plastic with black so it now has a FULL black int
* hella brand smoked rear tail lights(one has a small crack. But does not leak or effect the lighting
* euro round headlight conversion
* SMOKED E-code round headlights
* grill lip/eyebrow
* new windshield
* comes with German alum strut brace(may not fit with new turbo?)
* OEM GERMAN first aid kit in trunk
* all door handles work and so do the power door locks
* old school 16v style lighted key!!
Engine bay needs and other things that need addressing
This car will leave an oil drop when it sits over night only because I run the crank case vent to the ground.
* intercooler pipe rattles
* 4" turn down tail pipe got bent when I moved it on my trailer to my new house the reason I trailered it was because I was building the ss header during the move so it was taken apart and not running
* a/c condenser broken fitting(needs new or junk yard condenser
* coolant flange on head has pitting
* exhaust bend over the rear axle rattles on take off
* needs some wiring loomed and tied up
* recaro seats are Perfect except the drivers seat has one very small hole the size of a pencil eraser and a small 1" wear spot on the seat piping
* tires are ok but will need to be replaced sooner then later. it needed an alignment when I bought it and the tires are worn on the edges.
I know I missed some things and will update them as I remember...
Reply #36April 12, 2010, 12:04:44 pm
« Reply #36 on: April 12, 2010, 12:04:44 pm »
It just makes me sad Mark..
Seems like the end of an Era kinda..
Mines gone now your selling yours..
Truthfully I would love to have your car even if it just sat at the house..
Good luck my friend, I will do my best to send potential buyers in your direction
Dan
Reply #37April 30, 2010, 07:39:58 am
53 willys
« Reply #37 on: April 30, 2010, 07:39:58 am »
I'm pulling this off the market again......I cant bare to part with it...lol
Reply #38April 30, 2010, 12:59:59 pm
« Reply #38 on: April 30, 2010, 12:59:59 pm »
Your such a tease!!!   8)
Reply #39May 11, 2010, 10:33:59 pm
vwjunkie53
  • 98
    • The Volvo diesel forum
« Reply #39 on: May 11, 2010, 10:33:59 pm »
You will be glad you kept it... Every time I look at old pics of my 85 TD jetta I kick myself for selling it.  Seemed like a good idea at the time of course.  Your car is way nicer than mine was!  Just getting one rebuilt/running/reliable is a ton of work as it is.  Add in all the custom and performance stuff and you really have alot invested.  At least keep it and get some use and enjoyment out of it for a few years anyway.
Your build is one of my favorites, the car just looks damn good!
Jason
1984 Volvo 760 GLE,  "built" D24T w/ARP studs, MLS head gasket, ported/polished head, 3 angle valve job, NA cam, 56mm T3/T4, NA manifold, FMIC w/ 3" alum piping, 3" turbo back, detailed in CAT yellow. T-5 manual swapped w/ Clutchnet 6-puck.  Best of 16.07@86mph with orig. worn out engine.
Reply #40May 22, 2010, 07:58:35 am
53 willys
« Reply #40 on: May 22, 2010, 07:58:35 am »
Tune in next week for a re-listing...    :P
the car is sold and GONE to it's new home in PA....has been gone for about a month or so...it was a surprise gift for a graduating son and I could not let the cat outta the bag..haaha
Alex I hope you enjoy your new little diesel!! congrats!! 8)
Reply #41May 22, 2010, 08:02:40 am
Re: SOLD~BUY MY CAR~BUILT!!!! 1.6TD~ SOLD!!!!!!!
« Reply #41 on: May 22, 2010, 08:02:40 am »
I hope he loves it like you did.
Reply #42May 22, 2010, 08:26:56 am
53 willys
« Reply #42 on: May 22, 2010, 08:26:56 am »
me too!! I still love that car and will miss it...lots and lots of work into that little car...maybe we will get lucky and he will keep us up to date on the car.....
Reply #43May 22, 2010, 08:33:52 am
« Reply #43 on: May 22, 2010, 08:33:52 am »
when are you doing another? You have to have at least 1 VW diesel now.
Reply #44May 22, 2010, 08:56:36 am
53 willys
« Reply #44 on: May 22, 2010, 08:56:36 am »
Tune in next week when he steals it back from his son.   ;D
it's not my son who owns it!!...it's 3000 miles from my place so I wont be stealing anything ;)
I will miss it though
