Author Topic: BACK TO SQUARE ONE.  (Read 16503 times)
Reply #15October 14, 2009, 07:13:22 am
Re: BACK TO SQUARE ONE.
« Reply #15 on: October 14, 2009, 07:13:22 am »
I think you've got it.  But to clarify what I was saying:
See the little notch on the outer rim of the pump sprocket?  That should line up with the groove in the injection pump mounting bracket, directly above it.
Confused me the too first time when I realized there were two holes for the locking pin.   ::)
Good luck, hope that works out for you.
Reply #16October 14, 2009, 07:15:47 am
ashleyroe
« Reply #16 on: October 14, 2009, 07:15:47 am »
oh yeah i see it...
i'm so mad i didn't know this though.
i coulda just opened my bentley and probably saw this.
the only reason i figured out it was 180 out was that the little keyway is suppose to be facing the other direction.
the thing was we were expecting it to be some large problem and not something stupid like this.
so we weren't looking for it.
but we shoulda known better this being the first diesel we've ever worked on.
Reply #17October 14, 2009, 07:20:13 am
ashleyroe
« Reply #17 on: October 14, 2009, 07:20:13 am »
so looking at it that way brendan...
with those factors in mind that ididnt know exsisted...
it looked like this:
« Last Edit: October 14, 2009, 07:22:58 am by ashleyroe »
Reply #18October 14, 2009, 07:45:03 am
ashleyroe
« Reply #18 on: October 14, 2009, 07:45:03 am »
new question, does it matter that the engine you posted isnt my engine?
are these markings on all diesels?
i'm gonna go down a check out my old sprocket because i have the timing belt cover on right now.
Reply #19October 14, 2009, 07:56:37 am
ashleyroe
« Reply #19 on: October 14, 2009, 07:56:37 am »
i don't think i have that mark.
this is an old picture but i cant see anything.
Reply #20October 14, 2009, 08:07:02 am
ashleyroe
« Reply #20 on: October 14, 2009, 08:07:02 am »
no i do not have that mark.
this is what my sprocket looks like.
i dont have a huge bracket like that either i forgot to mention.
that blue mark is where the keyway is.
Reply #21October 14, 2009, 08:38:39 am
ashleyroe
« Reply #21 on: October 14, 2009, 08:38:39 am »
i think we're all set now, we read over the bentley.
i'll give an update to let everyone know how it goes tonight.
Reply #22October 14, 2009, 08:51:19 am
ashleyroe
« Reply #22 on: October 14, 2009, 08:51:19 am »
well maybe the new one on the car has is and my old pump didn't.
well shall see when we take the timing belt cover off.
my main point is this would be exactly what's causing my problems correct?
Reply #23October 14, 2009, 09:08:33 am
ashleyroe
« Reply #23 on: October 14, 2009, 09:08:33 am »
i'm not there to look right now but we will defintely inspect both sprokets of both pumps tonight.
Reply #24October 14, 2009, 10:34:52 am
« Reply #24 on: October 14, 2009, 10:34:52 am »
I think that "dot" on the face of your sprocket is your mark.
Reply #25October 14, 2009, 11:42:09 am
Baron VonZeppelin
« Reply #25 on: October 14, 2009, 11:42:09 am »
They say you only learn about 10-20% when things go right - as opposed to what you learn from when things go wrong.
Sorry all this fell on you like this AshleyRoe.
The last time i read about your car was when you had a flywheel timing mark/TDC issue after headgasket job.
Didn't know you encountered more issues.
Figured it all worked out and ran fine. And that you probably just did a Giles pump for more pimping.
Probably redundant now, but just in case. My primary education coming from lifetime of gassers, to diesel - in regards to pump timing relations -
was to consider the pump pulley as the rotor button
the pump housing as the distributor housing
the delivery valves as the distributor cap
the hard fuel lines as the spark plug wires
It pulled me into focus pretty easy and de-complicated the strange looking mysterious gizmo.
Lord V picture is A2 hardware, as opposed to your A1.
Good luck with it tonight.
Little car should be a different animal very soon.
Reply #26October 14, 2009, 01:33:13 pm
ashleyroe
« Reply #26 on: October 14, 2009, 01:33:13 pm »
thank you.
Reply #27October 14, 2009, 06:32:36 pm
ashleyroe
« Reply #27 on: October 14, 2009, 06:32:36 pm »
WELL!
the pump was 180 out! and guess what?
it starts right up and runs FANTASTIC now.
thank you guys and tyler for helping me out, so much.
video tomorrow!
Reply #28October 14, 2009, 06:36:20 pm
« Reply #28 on: October 14, 2009, 06:36:20 pm »
 ;D ;D ;D ;D ;D
Reply #29October 14, 2009, 06:45:44 pm
ashleyroe
« Reply #29 on: October 14, 2009, 06:45:44 pm »
i'm surprised on how fast it is.
runs sooooooooooo smooth.
i took it out for a spin to my friends house and i just couldnt get words out to describe how happy and amazed i was to my friend in the passanger seat.
