Author Topic: not much heat  (Read 12995 times)
Reply #15January 02, 2013, 07:31:30 pm
Re: not much heat
« Reply #15 on: January 02, 2013, 07:31:30 pm »
So if my vents are open with the fan on and cold air blows out of them even when I'm stopped, and hot air blows out of the dash vents, is this because I'm missing the foam?
IIRC, Mk1 vents at the end of the dash are always fresh-air, unless modded by the user.
Reply #16January 02, 2013, 07:42:19 pm
tyb525
  • 183
Re: not much heat
« Reply #16 on: January 02, 2013, 07:42:19 pm »
Should fresh air blow out of them when the fan is on, and the car isn't moving?
2004 Golf BEW, '81 1.6 NA rabbit (soon to be parted out)
Reply #17January 02, 2013, 07:44:45 pm
Re: not much heat
« Reply #17 on: January 02, 2013, 07:44:45 pm »
yes
Reply #18January 02, 2013, 08:48:45 pm
Re: not much heat
« Reply #18 on: January 02, 2013, 08:48:45 pm »
wuuut? LOL. If the fan is on, air is a blowin'. Looks like a Rabbit in your picture, if so the outer most dash vents are out side air always. Unless you close them personally at their respective locations, whatever temp air is outside will blow in. Regardless of dash selection.
Reply #19January 03, 2013, 04:31:29 am
Re: not much heat
« Reply #19 on: January 03, 2013, 04:31:29 am »
Some older cars had passive fresh air vents. Not VWs..
Reply #20January 03, 2013, 08:08:18 am
Re: not much heat
« Reply #20 on: January 03, 2013, 08:08:18 am »
As in, open vents to the atmosphere? Yes, I am aware. Are you aware you are logged in to a Volkswagen Site?  :P ;D ;) LOL jk jk.
Reply #21January 03, 2013, 08:13:06 am
nwcali6
  • 69
Re: not much heat
« Reply #21 on: January 03, 2013, 08:13:06 am »
My 96 Passat also has this problem, I've not yet yanked the dash apart, Instead I put in a 190 thermostat.  It made a noticeable difference and was much easier.  (my old one was only getting to about 160 before it would open though).
Reply #22January 03, 2013, 02:52:57 pm
tyb525
  • 183
Re: not much heat
« Reply #22 on: January 03, 2013, 02:52:57 pm »
Hey I've only had the car for 3 months and never owned a VW before that. Pretty much everything I know about it cam from this and other forums or the Bentley.
My truck has passive air vents, air doesn't blow out of them if I'm not moving, even if the fan is on. I didn't know if the rabbit was supposed to be that way or not.
Reply #23January 03, 2013, 03:07:54 pm
Re: not much heat
« Reply #23 on: January 03, 2013, 03:07:54 pm »
One very cold winter I was driving about 600mi in a rabbit and the vent seals were leaking badly... I pulled the dash vents out and stuffed my spare socks into the openings to stop the drafts.
Reply #24January 03, 2013, 06:38:22 pm
Re: not much heat
« Reply #24 on: January 03, 2013, 06:38:22 pm »
Socks! NICE.
Reply #25January 05, 2013, 06:20:22 am
Re: not much heat
« Reply #25 on: January 05, 2013, 06:20:22 am »
Ja, vacation clothes put to noble use.
Sometimes I like the MK1 setup... everyone in my family likes it much warmer in the cabin than I do, so I point that cold vent at my face. Who needs fancy passenger/driver heat controls?
Reply #26January 13, 2013, 09:12:34 am
air-cooled or diesel
Re: not much heat
« Reply #26 on: January 13, 2013, 09:12:34 am »
that picture helped alot, and wasnt that difficult. 2 8mm nuts and the front cover comes off(with some work). i used 3M super adhesive, it seemed to dry hard so you could tape(al, or ss)on one side as back door is impossible to get to. tape both doors and you have heat, lots of heat! marking door w/a marker while practicing helped me place tape on final attempt. i didnt tape all the way to the edges so tape wont peel off due to repeated movement of doors.
Reply #27January 15, 2013, 07:39:51 am
nwcali6
  • 69
Re: not much heat
« Reply #27 on: January 15, 2013, 07:39:51 am »
  Volkswagen touts their "German engineering" on TV now...  My 96 TDI has this problem, and I just received a 94 gasser (for free) and it does this also.  Foam blowing out the vents.  I also know older VW that do this.
  Has this never been addressed as a recall issue?  Slapping a piece of foam over a hole (that doesn't need to be there) and calling it good for that long is so "yugo" like.  I doubt even a Yugo would have done it..
  So why no recall?  Where did the consumer fail in making this very repeatable issue (happens on all of them I think) known?  Not to mention the crap door handles...
Reply #28January 15, 2013, 08:17:25 am
Re: not much heat
« Reply #28 on: January 15, 2013, 08:17:25 am »
I rekon recalls are for safety issues, warranty issues are for defects occurring during the covered period... 96 would be >16yrs?
Reply #29January 15, 2013, 09:04:08 am
nwcali6
  • 69
Re: not much heat
« Reply #29 on: January 15, 2013, 09:04:08 am »
When it comes to safety I don't think manufacturer defects apply the same.  I consider a almost 100% failure rate on a defroster a manufacture defect, and I could really care less if its 30 years old... It fails because its a bad design...
