Author Topic: lifted the head...now what?  (Read 4265 times)
Reply #15October 06, 2009, 10:35:57 am
gilligan5000
  • 63
Re: lifted the head...now what?
« Reply #15 on: October 06, 2009, 10:35:57 am »
interesting thread for sure!  :o Just another reason to switch to studs  8)
soooo...
getting back on track, are we all in agreement?
110ft/lbs using just oil as the lube?
Reply #16October 06, 2009, 12:11:30 pm
blackdogvan
  • 574
« Reply #16 on: October 06, 2009, 12:11:30 pm »
soooo...
Just don't fool yourself into thinking that's any different than less torque with the correct ARP moly lube. Be very careful with torque numbers & different lubes, some poor guy is going to read this & go torque his arp's to 110ft/lbs with the arp lube & break something. Using oil as a lube you should reduce bolt torque specs for a dry connection by 15-25%. Using a moly based lube (arp stuff) torque should be reduced by 50%. So adding 25% to the stock arp with moly lube recommendation & using motor oil makes no difference to the clamping force.
1991 Vanagon 1.9 mTDI
Reply #17October 06, 2009, 01:55:12 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #17 on: October 06, 2009, 01:55:12 pm »
 :o EEEEK! that was a scarey link you posted there Jay! I knew it was possible, so never tried to tempt fate but I had no idea it was that easy to trash a block!
