more supercharger talk
Pages:
22
23
24
25
26
27
28
29
32
Topic: more supercharger talk (Read 157955 times)
Reply #360
February 12, 2010, 02:49:48 pm
truckinwagen
Re: more supercharger talk
Reply #360 on:
February 12, 2010, 02:49:48 pm »
oop! you ninja'd me!
83 Opel Kadett Diesel
Reply #361
February 12, 2010, 02:51:49 pm
truckinwagen
Reply #361 on:
February 12, 2010, 02:51:49 pm »
actually, come to think about it, there could have been some adhesive residue left on the spring from the ID stickers they came in with.
maybe dissolved by the diesel and came off, gumming up a couple injectors for a bit.
Reply #362
February 12, 2010, 03:22:50 pm
truckinwagen
Reply #362 on:
February 12, 2010, 03:22:50 pm »
well, just fired it up and took it for a little drive(about a mile)
it started OK, but had an intermittent hesitation, like an injector was sticking for a moment.
not bad enough to make it hard to drive, just enough to notice.
the hesitation went away after about 1/2 mile.
I am going to guess that there was some adhesive residue on the new governor spring from the ID sticker.
this residue got semi dissolved by the diesel fuel and fell off.
these little globby bits(have to have been really small, as I didn't see any adhesive on the spring) got out into the injectors and stuck them for a bit until they passed.
I am going to take short trips to confirm that it is over before heading out very far again.
-Owen
Reply #363
February 12, 2010, 09:00:11 pm
truckinwagen
Reply #363 on:
February 12, 2010, 09:00:11 pm »
well, the exhaust leak needs to be fixed bad.
I have looked into fixing the downpipe, but it would require removing it, and then fixing it and I cant afford any more downtime.
I need a solution that can be done in an afternoon.
so I went searching for parts and found a good(with pics to prove it) OBX header for $120 shipped.
I am gonna snag it, install it and then repair the TT downpipe for future use/sale.
probably going to use the exhaust on the car now, until I decide it is not loud enough...
Reply #364
February 13, 2010, 04:53:37 pm
truckinwagen
Reply #364 on:
February 13, 2010, 04:53:37 pm »
well, took the GTI out for a drive today, still have some cylinders missing a bit when cold, but it clears up in a mile or so of driving.
I got the boost leak fixed and closed the boost bypass again, I forgot how much of a dog an N/A diesel is, but the power difference between boost and no boost is really incredible(and thats just 10PSI, I can only imagine what 20+ is going to be like)
I did some math for the water/meth injection system, and with both stages on, I will get five minutes of spray per gallon of fluid.
on the first stage I will get 15 minutes of spray per gallon of fluid.
which seems like not alot, but realistically as much as I will be at WOT in heavy boost I think it will do just fine(I might have to bring a couple extra gallons of fluid to the cruises though)
-Owen
Reply #365
February 15, 2010, 10:15:55 am
truckinwagen
Reply #365 on:
February 15, 2010, 10:15:55 am »
well, the smaller charger pulley and all my water/meth goodies should be here today.
one thing that is going to be a challenge though is that the smaller pulley is going to make the belt from the charger to the crank pulleys touch the idler in the middle.
as you can see clearance is tight as it is right now, and a smaller charger pulley will surely make it touch there
I'm not sure what to do, a smaller idler pulley seems the obvious choice, but I'm not sure where to get one, and adding another idler to lift the belt on top to clear is an option, but I would like to not add any complexity to the belt system, as there is plenty that can go wrong with it as it is(and it has seemingly worked fine thus far)
any thoughts on what I could do to remedy this?
-Owen
Reply #366
February 15, 2010, 12:17:16 pm
truckinwagen
Reply #366 on:
February 15, 2010, 12:17:16 pm »
well, some fellows over on the vortex were very helpful, and I have with thier help decided to run the belt like this:
should get rid of all my rubbing issues, and it shortens the length of belt that is unsupported going back to the crank, which will help keep it from flapping around so bad.
-Owen
Reply #367
February 15, 2010, 12:23:48 pm
Reply #367 on:
February 15, 2010, 12:23:48 pm »
Any chance of adding the clutched alternator pulley while you're at it? That will really help in the "flapping" department, and destress your crank sprocket as well.
Reply #368
February 15, 2010, 12:28:41 pm
truckinwagen
Reply #368 on:
February 15, 2010, 12:28:41 pm »
I intend to do that when I can get my hands on one of the pulleys for cheapish(or after my taxes come back)
it is in my list either way...
Reply #369
February 15, 2010, 12:37:07 pm
Reply #369 on:
February 15, 2010, 12:37:07 pm »
Quote from: truckinwagen on February 15, 2010, 12:28:41 pm
it is in my list
Reply #370
February 15, 2010, 12:37:28 pm
truckinwagen
Reply #370 on:
February 15, 2010, 12:37:28 pm »
just found a fellow on Ebay selling them for $45 plus shipping, but he has UPS listed as his shipper which puts shipping at $30.
I sent him an email asking if he would ship USPS to bring that cost down(to no more than $6 hopefully)
the other cool thing about going with the clutched pulley is it will allow me to go to a 6-rib belt!
Reply #371
February 15, 2010, 12:40:39 pm
truckinwagen
Reply #371 on:
February 15, 2010, 12:40:39 pm »
the slipping problems were due to it loosening itself(been fixed) and chewing the belt surface up.
I have fixed the loosening problems, and a little belt dressing got it to grab better, and stop slipping.
I do plan on going six rib when I can, but the five seems to work for now.
I am looking into having an adapter(for the alternator offset difference) machined to replace the crappy one I welded up out of pipe, so that the alternator pulley is more in line with the others soon as well.
-Owen
Reply #372
February 15, 2010, 04:30:39 pm
Reply #372 on:
February 15, 2010, 04:30:39 pm »
MIND=BLOWN
Reply #373
February 15, 2010, 06:36:55 pm
OM617
Reply #373 on:
February 15, 2010, 06:36:55 pm »
Since you need to add an idler on the bottom, now would be a perfect time to use an automatic tensioner.
Reply #374
February 15, 2010, 06:47:55 pm
truckinwagen
Reply #374 on:
February 15, 2010, 06:47:55 pm »
not sure I follow you there, I have an idler on the bottom, a timing belt tensioner.
it makes the belt wrap on the water pump better and allows me to tension the belt.
what "automatic tensioner" are you referring to?
Pages:
22
23
24
25
26
27
28
29
32
